6060 clutch
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: 6060 clutch
    Posted: 21 Oct 2017 at 2:05pm
We are splitting my dads 6060 for clutch replacement.
Splitting apart a foot the shaft to the transmission is still in the clutch pack. Is this normal? How far apart do we need for the shaft to clear the transmissiin?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2017 at 5:30pm
We moved it apart a few more inches and the PTO shaft finally slid out of the clutch housing.
Sliding the PTO shaft back into the transmission we can't feel it engage anything, is this correct?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2017 at 9:05pm
Has no one put a clutch in a 6060? The shop manual doesn’t give detail about removal of the clutch. The pto was not engaged when we separated the tractor just as the book stated. The pto shaft stayed in the clutch until we got it 11.5 inches apart and then it came out. We assume it reached a point where it couldn’t slid out anymore. Our question now is this a normal occurrence when splitting a 6060? When we slid the shaft back it doesn’t appear to engage into anything. It freely turns which I would say is normal since the pto lever is not engaged. The book says there is a coupling that can fall into the tranny if you have the pto engaged, which we did not. Any ideas?
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2017 at 9:11pm
Charlie, push it back in , no issue mine did the same thing.
Orange4ever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange4ever Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2017 at 9:14pm
Ours came out to we slid it back in why I held pressure on it the boy engaged the PTO lever in the cab PTO work as it should then we put the PTO lever in The disconnected position reassemble The tractor and clutch Rick done a great job on rebuilding our clutch and everything is been good
If you want a man to be a successful farmer, give him a Allis Chalmers tractor. If you want him to be a successful mechanic, give him a John Deere
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 22 Oct 2017 at 9:18pm
You can see the coupling which you are referring to if you take the shift fork plate under the left side of the platform off if you have a concern that something is not correct abut it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2017 at 5:45am
OK, thanks. Made us nervous.
Wish the manual had a Note "PTO shaft may slide out"
My First double clutch!
Another question regarding the throw out bearings, normally these are just slide on/off. Since this is a double, is there a different procedure?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2017 at 6:30am
Picture for reference
2075 hours on tractor, just doesn't seem like the clutch lasted long enough.
Charlie
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2017 at 9:05am
Here is a picture of when I did a 6080.  Yes the PTO shaft was stuck in the pilot bearing and pulled out.  I pushed it back in, no problems with it when put together.
The release bearing forks are held on with a lock bolt to the shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Oct 2017 at 9:19am
Thank you
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 7:40am
We are sending the clutch pack to Rick for him to do his magic. When reinstalling the clutch, should we pull the pto shaft back out of the rear and slide it into the clutch as we are sliding the tractor back together? Just seams like with the shaft already lined up in its clutch it will make it easier to get main clutch splines lined up instead of fighting them both.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 11:33am
I didn't,but you will need to make you a line up tool. Rick did mine and did a great job. Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2017 at 9:43pm
I would leave the shaft fully installed if it was me.
ewbs79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ewbs79 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2017 at 11:06am
So I am asking on a 6080 is there an inspection window for the throw out fork? Clutch quit working this morning. Push the pedal it doesn't disengage
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2017 at 11:41am
No window on the 6060 not sure about a 6080. When we replaced dads clutch we removed the cotter pin on the bottom of the housing and drilled the hole out larger to get my brothers camera probe in there to look around. It has a frexable head about a foot long. It allowed us to see while lining up the clutch. Not sure if we can see the throw out bearings and forks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2017 at 3:06pm
Clutch cable break?
Charlie
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2017 at 8:49pm
Clutch cable break?
Most likely.  There is no inspection window on a 6080.
