WD 45 piston rings?
AaronH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronH Quote  Post ReplyReply Direct Link To This Post Topic: WD 45 piston rings?
    Posted: 10 Oct 2017 at 2:11pm
I posted on here quite a while ago about some oversized wd45 Pistons (4.125) that I pulled out of a motor. I can't find a number or any Maker's Mark on the Pistons, and the Pistons rings I got from the local dealership from A&I are the wrong thickness.. well the two middle compression rings are the wrong thickness, they're too thin. the top compression ring and the oil rings fit.. I know a member on here said they had what I needed, can't remember who.. it's finally time to finish this project and I wonder if anybody on here can hook me up with a set of piston rings? I will get the thickness if need be, I just don't have a micrometer here with me. Thanks in advance for any help.
Edited by AaronH - 10 Oct 2017 at 2:24pm
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2017 at 5:51pm
Try calling Tony, he can help you out.
JimD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimD Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2017 at 7:30pm
Get me the specs on sizes, and I should be able to match them up.
