82R Mower
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: 82R Mower
    Posted: 02 Oct 2017 at 1:50pm
Working on a 3 point 82R mower my dad purchased new in 1968.
It was put in the weeds several years ago due to constant repair of the knife Bar.
I dragged it home and am seeing what is needed to run again
The Knife bar is broke close to the head. Looks to have been welded several time.
The knives are rusty but in good condition. Surprising as dad sharpened the heck out of them most of the time and wore them down a lot.
Guards, most of been broke and welded. Looks to be several different kinds on it.
3 of the 9 Top guides (Not sure what their actual name is) are broke.
The Bar Groove has a wear plate that is worn down pretty good. Also looks out of line which was maybe why the bar was binding.
The rest of the mower is OK, Gear box was full, the bearings are tight.
So is it worth fixing for light use? It will mow pastures and such.
Good places for parts? Need a bar, knives, guards, wear plate.
How do I figure out what size he bar groove is? I see 3/4" and 5/8" in the parts book.
Charlie
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2017 at 2:01pm
I rescued an 82r3 this spring. Take one of the guards to someplace like Tractor Supply and match them with new ones, sounds like you need a whole new sickle. If you get 1 make sure it has what is called chrome sections on it. They are a lot tougher than black steel ones. Tractor Supply should have everything except the sickle bar. You will need wear plates under every sickle hold down bracket, I used bolts to hold the sickle together, that requires a little taller sickle hold down bracket. Bolts are a lot easier for me to use than rivets. Sounds like you will need to replace the hold downs anyway. Good luck with your mower. If you can't find the sickle bar I have seen guys switch ends with them and put the broken end to the outside of the bar.
Edited by HD6GTOM - 02 Oct 2017 at 2:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2017 at 2:19pm
The double New Holland guards work great. HTH Tracy
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2017 at 4:13pm
If sections have ever had a grinder put to them they are never really sharp again.You
can get a better than new/original sickle assembly from Webb's Sickle Service they have a
heavy made all steel head used them for years until I went to NH mowers.I have about
30 Twin Wheel Drive mowers around here suspect you could find some parts on them
plus I have some NOS parts too.Loose/worn bearings on the rear of the arms are the
No. 1 reason the sickle head breaks and No.2 is the bushing where the blade bolts up
has slack in it.All that has to be in really good shape for the mower to work like it should.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2017 at 5:29pm
I also have many NOS and used parts for those mowers. I know that I have a few NOS knifeheads.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2017 at 5:40am
I did run across Web the other day but didn't know if they fit.
Seems like a good price.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2017 at 5:41am
Paul I might need to come for a visit!
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2017 at 8:09am
Neighbor recommended changing over to the 1.5" Tiger Teeth blades and Guards.
Opinions?
Reading online they are great in grass, but weeds the 3" are better.
Cutting grown up fields will be what this is used for, or pasture cutting weeds.
Charlie
