Cab switch |
Mar,D
Topic: Cab switchPosted: 01 Oct 2017 at 12:43pm |
New to Forum, may be asked before, but does a cab from a 190 fit on a DT -17 series 1V .
JarrodACFan
Joined: 24 Jan 2012 Location: Delaware Co. IN Points: 732 |
Posted: 01 Oct 2017 at 2:26pm |
I would say no. A 190 is somewhat different than a D17. For starters, the sheet metal on the dash/hood isn't the same. Also, the 190 had more of a flat floor because it sat up above the transmission and rear end. The "platform" on a D17 was made down around the transmission. Could you get it to work with enough re-engineering, sure. Would it be anywhere close to easy? No. You'd basically have to redesign and rebuild the whole operator's station on the d17.
1956 WD45 Narrow Front Factory Power Steering, 1953 WD Wide Front
Allis Express in Muncie, IN |
