Gleaner K Concave Tool
KGleanerIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KGleanerIA Quote  Post ReplyReply Direct Link To This Post Topic: Gleaner K Concave Tool
    Posted: 13 Sep 2017 at 8:20pm
Hi,
How can I make a tool to open the concave door on a gleaner K?  I was told it looks like a tire spoon.  What is the spoon part for?  Do you use the tool to open and close the door?
Thank youSmile
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 8:23pm
Any model that has one will be the same. It would be easier to check a junkyard for one. It is similar to a tire spoon but it has a loop welded to it. The spoon part is for prying the door open and closed. The loop will engage the latch.
Edited by Dans 7080 - 13 Sep 2017 at 8:37pm
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 8:28pm
What Dan said Wink
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 9:10pm
I remember using one, it was on an "E" mid 60's.  Don't recall measurements though!
I was working on the light ground, and opened/closed the door a number of times.
A steel rod about 16 inches long with an inch long piece of tubing to slip over the latch lever, spoon/flat like a screwdriver(large) both on same end of tool, stored on? oops, forgot.  Two brackets with holes where tool could slip through, I think on one of the elevator thingy's, close to the steps.  Here I am  rambling on.
A tire lug wrench a an end of tubing welded to it will work
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 9:16pm
Now that Joe mentioned the 2 brackets, are you sure it is not hanging on the clean grain elevator about eye level ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 10:13pm
I always used a 2 ft long conduit pipe, unlatched it and the door would fall open
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 10:14pm
oh...and don't sit/lay under where the door opens....
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 10:18pm
X2!! Can't stress that enough!! I learned that the hard way. If you can, always park the combine perpendicular to the wind, and stay upwind from the door.
When you go to shut the door, you can lay on your back and use your legs to do most of the work.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 10:24pm
Here is my dad's F3.  See the wrench hanging on the clean grain elevator as the previous post mentioned?  Sure it's not there on yours?
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 10:26pm
And be careful when using your leg to close the door.  Heard of it slipping off a foot and having the lever right back in between the legs.  Don't want to try that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 10:29pm
That's why I usually lay offset and use my outside leg.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2017 at 9:00pm
Maker sure you put tool on lug the right direction or you will bend or break lug.     MACK
