7020 Hydraulic Pump
leader58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leader58 Quote  Post ReplyReply Direct Link To This Post Topic: 7020 Hydraulic Pump
    Posted: 08 Sep 2017 at 8:27pm
Has anyone ever had one of these rebuilt? My remotes have started to bounce like air is in them and i was told the pump is getting weak. Seems to get worse when hot. Raising and lowering a disc conditioner.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2017 at 8:43pm
Yes, it is very easy if you are detail oriented.
First question, is have you check pressures, both standby, and operating?  Does this pressure fluctuate back and forth from standby to operating, while in operating mode?  It may not be the pump, the pump may be being commanded via the sensing circuit to rapidly fluctuate pressures and flow, because of some problem elsewhere.
Do a flow test, and see if you really are getting air, (foamy oil) or just fluctuating pressures.
If you are really getting air, the first thing I would check/due, is put new o-rings on the back side of the swash plate trunnion bearing covers (about 1-1/2" inset round covers opposite sides of the pump)  If those get loose, as I have seen them due, they pull air in from there.  If you clean things up real well, you can do this easy repair right on the tractor
Still in use:
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2017 at 9:42pm
How is steering? Is it jerky at any time? Does three point come up smooth?
MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote leader58 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2017 at 5:04am
steering and three point work great
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2017 at 6:26am
I would say cables need adjusted on remotes.    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote leader58 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2017 at 7:39pm
I assume you mean they are not opening fully?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2017 at 9:38pm
Yes.    MACK
This page was generated in 0.190 seconds.
