Supplier for Ross Steering Box Parts
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: Supplier for Ross Steering Box Parts
    Posted: 10 Jul 2017 at 8:11am
Is there a company who still makes/sells the Ross steering box seals/parts?
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2017 at 10:39am
Ross Gear -TRW is still in business. Lebanon, TN. HTH
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2017 at 6:57am
Now that's interesting.......
Ross put steering gearboxes in Studebakers too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2017 at 6:58am
What's wrong with the one you have?  I know of a couple tricks if the case isn't busted.
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2017 at 8:15am
You can get the bushings and seal at a bearing supply.
Seiner Tractor, and others have aftermarket lever shaft, or you can install a new "Pin" in the old lever shaft.
I have never found a source for a new worm shaft.
Bill B
