AC 7000 clutch safety switch
EDD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EDD Quote  Post ReplyReply Direct Link To This Post Topic: AC 7000 clutch safety switch
    Posted: 06 Jul 2017 at 10:54am
Anyone know where the clutch safety switch is located. I know it has to be somewhere in the clutch linkage! Was wondering if'n I have to remove the fuel tank to get to it? Thinking about by-passing the switch. Any helpful instructions would be appreciated? Looking up under the tractor I cannot seem to locate it?
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 10:55am
Should be under the dash.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 11:01am
Under the floor mat just inside the cab door about 10 inches. There's also one on the PTO valve behind the batteries.
EDD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EDD Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 11:07am
you saying it is NOT on the clutch linkage under the cab? Woulda thought it has to be connected to the linkage?
EDD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EDD Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 11:12am
i'm having to depress the clutch 15-20 times to get it to roll. Assuming this IS the switch problem? I suppose I can pull the wires and tie them together and eliminate the switch? Can that be done thru the floor panel?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 11:17am
I'm saying it is under the floor mat, under the cab floor, underneath an access cover in the floor and yes, the clutch pedal rod touches the end of the switch.
EDD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EDD Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 11:22am
thanks, will check it out
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 1:25pm
If you mean roll, as in engine roll over to start???????? The switch will be adjustable with 2 nuts , just move it down to get the switch to make contact if you still want it
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2017 at 1:46pm
Yes, that switch needs to be adjusted as the linkage wears… I've done mine years back.
If you look behind the fuel tank under the firewall of the cab you should see it.
This page was generated in 0.254 seconds.
