New Holland 1033 Stackliner
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Topic: New Holland 1033 Stackliner
    Posted: 06 Jun 2017 at 9:44am
A friend of mine and I are looking at ways to make our small haying operation faster. One of our big problems is lack of manual labor to load and unload our small square bales.   Loading and unloading in the wagons stacking the bales, it all takes too much time. Friends and relatives make themselves scarce around haying time. We found a 1033 stack liner for sale not too far away and are wondering if anyone has any experience with them. Would our D17s have enough power to run it? Do they work well? Prone to problems?
Cheers,
Creek
Have spacesuit, will travel
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2017 at 9:59am
I owned a 1033 for several years.  Their one weak point, literly, is the frame under the first table has a habit to crack.  The 1037 solved the problem with a stronger frame.  In general, they take a bit of practice but as you watch each bale go onto the machine, your back says "Ahhhh"!  You need a good level spot to stack, a slight incline to the rear is ideal.  Basically, they just take practice.  I pulled mine with a David Brown 1200 which is about the size of a D17, so unless you have steep hills, you should be fine.
Allis Express participant
AllisandGleaner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2017 at 11:27am
Yeah we have one on the farm and pull it with a 2510 Deere wide front with 2 rows of weights in the front but when you have a load of hay on that thing it's a load and the front end becomes real light even with the weight it's still light on the front.
Brad in WA View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad in WA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2017 at 8:13pm
I've used a 1033 for 12 years behind a D17, works very well. The only way to handle hay as far as I'm concerned.
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2017 at 8:18pm
I bought a 1033 two years ago and pull it with my D17 ser.3 NF gas tractor and it works fine but I do have mostly flat ground. I researched NH bale wagons for months before deciding on the 1033. The 3 bale wide makes a nice stack and the 1033 has "auto tie" as standard equipment. The tie layer really helps make the stack more stable. The first season will be a "learning" season if you have never used a bale wagon. Most all dealers for used bale wagons say the 1033 was a very good model. Proper bale length is mandatory along with tight well shaped bales and NEVER leave bales on the ground overnight. I paid $4,500.00 for mine and after a few parts,repairs,1 new tire paint job and decal kit I've got around $5,400.00 invested in it. It works absolutely perfect and I love it.
Don (Utah) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don (Utah) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 12:02am
I have used a 1033 for several years, the D17 works great! series 4 works best with a heavier draw bar. I bent the series 2 draw bar.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 8:29am
How do you move the large stacks left in the field?
Charlie
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2017 at 2:51pm
We had a 1034 when I was young. Now we have a 1069 self propelled. 800 bales after work is a normal day for me by myself. I will second bale length consistency and good heavy tight bales are a must.
Charlie we dump the stacks in the barn. The only down side is it takes a tall barn. We have a 60x75 with 18' sidewallls. 1033 will want 12' I believe.
Edited by wekracer - 07 Jun 2017 at 2:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2017 at 12:02am
The side boards are adjustable but a bale about 38" seems right, I try for 55 lb bales.  New Holland also makes a retriever that mounts on a two ton truck.  Makes moving and delivering easy.
