7050 circuit breakers
45 turboa- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 45 turboa- Quote  Post ReplyReply Direct Link To This Post Topic: 7050 circuit breakers
    Posted: 27 May 2017 at 11:53am
On a 7050 is there more circuit breakers than the 2 on the fire wall. There are no dash lights or gauges working until the tractor unless the tractor cools down.  Also won't start with stater button unless it's cold.  Any one with an idea !   Thanks  Paul
turbocharged
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2017 at 1:01pm
There is one on the key switch, but it is usually not the problem.
210Postin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2017 at 8:08pm
Put a load on wire from starter to breakers sounds like that wire is your problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2017 at 9:13pm
When nothing works, start at starter with test light and follow wires until there is no more current. Then that is the problem.    MACK
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2017 at 9:30am
I've had a corroded connection at the switch breaker and caused the breaker to get hot and quit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 45 turboa- Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2017 at 10:59am
I'm pretty sure it is one of the breakers any one know how many amp they are. I got the tractor  going yesterday so he could finish plowing. we have had so much rain every thing is getting late. A lot of the fields that got planted got washed out.  Still water standing in some fields.
turbocharged
