Again I Am Thankful For My Scrap Yard (Pictures)
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Topic: Again I Am Thankful For My Scrap Yard (Pictures)
    Posted: 16 May 2017 at 9:14pm
Having clutch and pressure plate and torque tube laying around was the last deal. This after noon I started mowing the front yard when the fan belt started to smoke and then spit out the side. The generator seized up. I found an old narrow belt about the correct size and after looking around I found a generator with a narrow pulley. I sprayed the adjustable fan belt pulley with WD40 and went in to eat supper. I came out and loosened the two nuts, took a large blunt screw driver and after a few whacks with a large hammer it tracked back tight in the center. I had to place 3/4" of washers behind and find a longer bolt to make the belt tightener work. Took the old girl out a 9 PM and mowed the rest of the front lawn.
Edited by Dick L - 18 May 2017 at 7:55pm
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 4:25am
the wife complains about all the junk I have laying around, but when something breaks and all I have to do is find the part (which could take all day....lOl).  then she don't mind it.  ya can never have to many spare parts around....and a good knowledge of how to rig things together helps..Smile
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 6:41am
Guess I need to get started on collecting up some spare partsLOL
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 6:47am
  Wink,,,I call it my "Laydown Area" and like ole Dick,,has saved me lots of times and,,,,and,,,I don't ever miss a chance to remind the Wife how much money I "didn't" have to spend,,,cause I fount a piece in thet dang laydown area,,,,,she just shakes her head and walks off,,,,,,Wink
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 7:33am
I call it the "healing shelf" because you never know what you might need to make the piece of equipment you're working on all better.
Leon B
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 7:41am
I call my mine "home" LOL Just about everywhere you look there could be "junk" that I might be able to use to fix something. Just yesterday I used an old wheel barrow wheel that's been laying on the shelf in the shed to fix up an old 3 point rake.
[TUBE]dBCNV9SaxKk[/TUBE]
Edited by CTuckerNWIL - 18 May 2017 at 7:43am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 8:03pm
I'll start with the last first. The adjustable water pump pulley that some have problems with. As I stated before I take them apart when rusted together with heat and tapping with a hammer as I apply heat. I then sand until I can slide them in and out before assembly. You can see by the picture where it moved from.
The old belt is a little long and most likely will not last the summer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 8:17pm
This is how I stabilize the tractor when splitting it. I have it off the ground on the jack stands.
I use the engine lift to pull the engine away.
The sheared cotter key.
Where the drive shaft splines were stripped.
The drive shaft I used as a replacement.
Replaced the cotter key with a grade eight bolt.
Back together with different torque tube.
Almost forgot-- The old torque tube. I think I broke it taking it off.
john2189 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john2189 Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2017 at 9:24pm
That broken torque tube will make a perfect bench grinder stand.  Thats what I have mine on.
john
'41 Allis B
'45 Allis B
'49 Farmall Cub
'72 IH Cub
FredinInd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredinInd Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2017 at 4:29pm
Been there, done that!
Oh well, I won't do that again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 10:01am
Great idea!
You're lucky to have all them spare parts laying around Dick!  I'm still working on it.  LOL
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2017 at 2:23pm
All good mechanics have a parts pool.  Old stuff that just may come inhandy some day.
Outstanding job sir.
Good Luck!
Bill Long
