d14 brakes
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Topic: d14 brakes
    Posted: 07 May 2017 at 8:46am
went to take the d14 down the drive way and couldn't get it stopped.  decided to see what was up.  as you can see it looks like I gotta replace a seal and brakes.  ahh the good times of farming, guess the neighbor was right, farming is easy and cheap!!!Angry
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2017 at 5:12am
while I was pulling the final drive out, I was going nice and slow and expecting something to go wrong, things were going to easy.  I was just about past the threads on the studs and all of a sudden there was this loud noise, I froze up, couldn't move, what was that....air compressor kicked on, just about gave me a heart attack!!!
back to the brakes, I was able to clean the shoes with some acetone and bake them on my wood pellet stove to get the grease out (should be good for another year any way, (finances don't permit getting them now).  It almost looks like it has a double seal?  I noticed they have different seals for serial number 19001 and lower.  my tractor is a 1960 so it's past that serial number.  guess I'll find out at the bearing shop this morning.  I can read the number on the seal so hopefully it's an easy find, unlike the 5020!!!!  The little 5020 has be a bit gun shy when I have to get parts.  ain't no fun going to a parts store, asking about a part and they look at ya like ya 3 heads!
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2017 at 10:48am
skf seal number that i put in mine is a #12456    $7.30 at NAPA
dan
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2017 at 11:24am
well, it looks like somebody put 2 seal together? one side done and now the brake works.....have the other brake shoes baking, yummy!!! what a beautiful smell, axle grease cooking...DeadDead
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 6:20am
hmm now that you're the 'expert' , I've got 3 D-14s here that need your talent.....
sad thing is yours probably is CLEAN compared to what I'll see....yuck...
sigh....
I know, I'll get around to at least one side of one of them, maybe, this summer
Kinda hard to get motivated when it's 33*F here though !!!
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 7:37am
sigh....
Jay
we've had temps in the 40/50's but 50 mph winds and rain.  glad I have a 2 car garage.  the 5020 on one side with the front end tore apart, the d14 on the other with the rear end tore apart!!!!  If ya were closer I'd be glad to help..
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 7:41am
You need another tractor and a bigger garage of courseLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 1:33pm
defiantly a bigger garage!!! maybe another tractor that is harder to find parts for than the 5020, just to make it sporting!!!Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 1:52pm
I can find out about the UTB 800 I used to own,it was the only one I could find in
North America.Be right up your alley.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 4:42pm
be about right.lol
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 5:35pm
You drive around on ur hills using them brakes hard ,that oil that u did not get out of lining will be coming out .
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 4:05am
I'm just hoping to make it through a few projects I need the machine for and by then I should have enough saved up to put new brakes on.  I cooked them on the pellet stove until no oil came out of them..  Now I'm not sure I put the axle seals in the right direction, so I might be doing this again sooner than I thoughtAngry  The good thing about the d14 is the engine holds ya back when going down a hill (one of the reasons I was looking for a d series), that should help save the brakes.
Edited by dt1050 - 10 May 2017 at 4:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 8:59am
well the Allis Fleet is back together and working.  Finally!!!  next time I remove the floor boards on the d14.  the bolts for it that hand down from the final drive kept getting hung up on the floor board, keeping the final drive from going in.  but feels good to have the 5020 and the d14 back.   thanks for all the replies, dt
bobkyllo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bobkyllo Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2017 at 9:22pm
Don't put it back together with the old oil soaked linings. The lingings are very cheap. I bought mine through the agco dealer. I'd like to say it cost like 30 dollars. That come with the rivets. I know you say money is tight. I never religned a set before either but it was very easy to do. I borrowed a neighbors riveter but you can do it with a couple punches and a helper
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2017 at 7:16am
it's been about a week and I've tilled up 3 gardens, took the brush hog for a drive, drove up the steep upper pasture road and so far the brakes have been good and stop great.  so I must of cooked most of the oil out of the shoes.
This page was generated in 0.053 seconds.
