Planting Sunflowers
dink View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dink Quote  Post ReplyReply Direct Link To This Post Topic: Planting Sunflowers
    Posted: 02 Apr 2017 at 8:58am
I have AC 72 unit planter. I'm wanting to plant sunflowers. Does a corn plate work on sunflowers? Thanks
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2017 at 10:18am
No, you will need different plates but the seed dealer should be able to get them for you.
clarkscreek View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote clarkscreek Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2017 at 10:22am
I don't if the plates you have will work, never did sunflowers but I had an allis planter with the adapters to use jd plastic plates. I was able to plant quite a few different garden crops by just trying different plates until I found some that were acceptable. Not exact or picket fence rows but good enough.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2017 at 11:46am
Can you find a neighbor to custom plant with a Deere finger pick up?   Had pretty decent success with flowers planted by a Deere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2017 at 12:10pm
Usually have a filler plate and then the seed plate, seeds are thinner than corn, I suppose if you are not planting alot and not too fussy about population you maybe able to make it work but would have a job figuring out planting rate.  Plates are pretty cheap compared to seed costs and a poor stand.
Travis2766 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Travis2766 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2017 at 7:47pm
I plant sunflowers mixed with corn seed for food plots with my 495 John Deere planter, have had no problems since I've started doing this. Going to try straight sunflowers this year. As long as the seeds fit in the slot of the plate you should be fine. I pick a plate that fits the seed well and then throw a handful of seed in the hopper and turn the plate by hand to make sure the seeds feed into the slots and not get ground up by the plate. I plant soybeans with corn plates in the same fashion and have had no problems.
190XT Series III, D17 Series IV, D15 Series II, All Crop 66, Rotobaler.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 7:29pm
planted about 1/2 acre of sunflowers and 8 long rows of sweet corn for my honey bees.....
