AC d17 3 pt issues
n17cattle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote n17cattle Quote  Post ReplyReply Direct Link To This Post Topic: AC d17 3 pt issues
    Posted: 31 Mar 2017 at 10:15am
HI i have a 57 d17 diesel, works great accept i cant get the 3 pt to lower, a local guy suggested cleaning the screen or rebuilding the valve, was hoping to here if this was a common issue and likely fixes or at the very least, where the hydraulic screen is located.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2017 at 10:36am
Is your traction booster lever set in the lower position (lever is horizontal )?
EO_09 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EO_09 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2017 at 7:35pm
New member here long time lurker a lot of great information here. I have a 1959 D17 gas that has done the same thing. Is there an adjustment on the hydro pump? The traction booster lever is down as well as the lift lever. Any ideas? Thanks
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2017 at 9:49pm
The next time you're going to use it for a while, put a qt. of enamel thinner in the system Don't worry about it being in there too long, because it will evaporate out before very long. It cuts the varnish and dirt. You need to change the filter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2017 at 6:51am
There is a small pin in hold poison valve that pushes a ball off it's seat to lower. Some times the pin brakes so nothing to unseat ball. Pump has to be removed to repair.     MACK
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2017 at 8:13am
Have you put any weight on the three point arms at all. .? Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote EO_09 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2017 at 12:45pm
I have took a long 2x4 and tried to pry down but it wont give any. Sorry to hijack your thread 17 cattle I just had the same thing going on as you hopefully we can get it figured out
Post Options Post Options   Thanks (0) Thanks(0)   Quote EO_09 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2017 at 7:17pm
thoughts?
