7045 Clutch Issue
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Topic: 7045 Clutch Issue
    Posted: 24 Mar 2017 at 10:46pm
 After I push in the clutch pedal the pedal does not spring back out. To get the cutch to re-engage I must pull the pedal back out with my hand. I first checked the return spring on the clutch pedal, but the spring is in good working order.
 What else could be wrong?
Thanks & God Bless
Dennis
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 7:33am
If it's a power director, it's the clutch cable sticking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 9:28am
Clutch cable. I agree.    MACK
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 3:13pm
Happy to see this post and the responses! My 7045 started doing this last week also. Started that when I used it clutch to kick the pd from high to low to turn corners it didn't relase like it should. It was verydusty and I figured I just needed to take the floor panel out and give everything a cleaning, then it started acting like you described and I was getting scared. I finished planting and hadn't got back to dig in yet but was starting to worry. I had replaced the cable once, but as I think about it that was close to 1000 hours of work ago!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 4:07pm
I call my dealer first thing this morning to get the cable on order. To my surprise they had one on hand. So I picked it up and started removal of the old cable. Didn't realize how much tin had to come off just to get to the 4 points holding the cable on. The cable was the issue. Not sure why as it looks so simple. Glad I didn't need to split the tractor.
Would it be wise to put a lubricant in the new cable before installation?
Thanks for all your help.
Thanks & God Bless
Dennis
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 6:34pm
I have tried to lubricate the cable before installation, but that just seems to collect dust. There is a hard liner inside, that the cable rides against, and once that has worn through, not much you can do but replace it.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2017 at 9:18pm
I would pull the pedal off and grease its shaft while your at it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2017 at 8:06am
Lubricate the fork assembly down low and make sure the bronze bushings are in good condition.
