WD45 Question
Bob4430 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob4430 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Question
    Posted: 09 Mar 2017 at 11:57am
Does aany one know if the wd45 was ever made without a pto i have one that does not have a pto shaft coming out the back
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 12:22pm
Yes, they were available without. Are you sure you are missing just the PTO shaft??? or is the PTO drop box is still down underneath the battery ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob4430 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 12:30pm
what does that look like
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 1:34pm
The PTO shaft extends from the rear of the tractor to the underside of the transmission. About three feet long or so. There will be a drop box which is just a housing that hangs below which houses a couple of gears and short shaft that comes out the back side of the drop box. That short shaft connects to the long PTO shaft with a shear pin to protect the driveline.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob4430 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 1:40pm
Can all that be added if it is missing
stu(ON) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stu(ON) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 2:29pm
It is possible that a previous owner ripped the guts out of the PTO and blanked it off with a cover at the casting and then sold the tractor.  You would not be the first.  Unbolt the cover that is in place and look up and see what is there.  Take pics if you can.
http://forums.yesterdaystractors.com/viewtopic.php?t=984847&highlight=pto
Edited by stu(ON) - 09 Mar 2017 at 2:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 7:17pm
That is supposed to be a shoulder bolt and was never intended to be a shear point. ANY tool ran of the PTO should have a slip clutch or a shear pin in it to prevent damage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob4430 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2017 at 12:16pm
does any one have a number i could text some pics to to show what my tractor has for pto parts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob4430 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2017 at 12:20pm
do you have a number i could text u pics of tractor so u can tell me what i missing
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob4430 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2017 at 12:21pm
Do u have a number i could text u pics of my tractor to see what im missing heres mine 417 260 1033
Post Options Post Options   Thanks (0) Thanks(0)   Quote stu(ON) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2017 at 1:39pm
To see parts explosions, go to this site:
http://www.agcopartsbooks.com/PartsBooksN/login.aspx?region=NorthAmerica
Under Guest User, View Books.
Under Search by Model, enter WD45
Under All Brands, pull down AGCO Allis
Under WD....., scroll down to Drive Train - Power Take-Off and the parts are all pictured
Go to this site:
http://www.grandpastractor.com/forum/allis-chalmers-tractors.html
And down load Operators, Service and Parts Manuals
Also check your e-mail.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob4430 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2017 at 2:20pm
Ok thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2017 at 2:20pm
Thanks for catching my mistake Charlie. I must have been daydreaming of the other end of that shaft. Mine also has the shoulder bolt where it's supposed to be.
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote stu(ON) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2017 at 4:41pm
Bob4430, the pics that you sent don't show any of the external PTO parts being there.  However, the right side view of the steering column support shows the loop that would support the actuator rod for PTO.  There is still a good chance that the tractor originally had PTO and it has been removed.
You need to drain fluids and look inside to see what is there.  Then, you can see what you need, maybe with the help of others on this forum.
Here are a couple of more old threads that will help you appreciate why you need to look inside.
http://forums.yesterdaystractors.com/viewtopic.php?t=1011717
http://www.allischalmers.com/forum/forum_posts.asp?TID=70201
http://www.allischalmers.com/forum/forum_posts.asp?TID=93382&title=wd45-hydraulic-tank-same-as-wet-clutch
http://www.allischalmers.com/forum/forum_posts.asp?TID=120328&title=how-to-or-not-to-split-wd45-replace-seals
Post Options Post Options   Thanks (0) Thanks(0)   Quote stu(ON) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2017 at 5:46pm
Here is something quick to look at.  Go to the online AGCO parts listing for WD/WD45 and go down to:
Drive Train - Torque Housing, Transmission Clutch
Item #16 is the Covering for the PTO Opening.  If yours is original, it will likely have a drain plug installed.  If no drain plug, then it is likely farmer installed and you will have to look inside to see what is left.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2017 at 7:22pm
In order to use the mounted plow you needed to remove the PTO shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2017 at 7:49pm
on a pin hitch but not a snap coupler(like a 45 had)
