7060 no reverse in tranny
iluv2694ubaby View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iluv2694ubaby Quote  Post ReplyReply Direct Link To This Post Topic: 7060 no reverse in tranny
    Posted: 08 Mar 2017 at 7:17pm
I have a 7060 that has a powershift and it wont work in reverse now I have cleaned the filters and the valve body and when put in reverse it seems like it trys to go forward what could be causing that and how one go about fixing it
Post Options Post Options   Thanks (0) Thanks(0)   Quote iluv2694ubaby Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 7:18pm
and no shop manual either to see if there is a way to check
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 8:55pm
Make sure cable is moving shifter all the way. Does it work ok in  all the other speeds? Put shifter in reverse then go to valve body and see if lever out of valve will move any farther by unhooking cable. Lever on valve gets loose on shaft.   MACK
Strady View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Strady Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 9:06pm
I had the same thing happen to my 7010, it ended up being 2 clutch plates and a bad seal. There is a way to check pressures to determine what's wrong!
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 10:19am
If the lever issue Mack describes isn't the problem, you need a set of gauges to take some readings, on the test ports to get to the next step.
Still in use:
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 12:29pm
Worst case scenario if you do all of above and everything checks out, then I would suspect the inside teeth on the C2 clutch packs have failed, thus not able to drive the hub = no reverse. There is always a certain amount of clutch shutter, high reverse, and over time it takes its toll on the teeth. This was an update on the friction disks, something about the teeth being harder. Dr. can provide more ideas, I'm just speaking from experience. Good Luck, Mike
Kevin in WA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin in WA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 5:46pm
C2 clutch is also used as transmission brake and if abused can cause wear of the inside teeth, have also seen the plates split open.
Post Options Post Options   Thanks (0) Thanks(0)   Quote iluv2694ubaby Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2017 at 8:38pm
I also don't seem to have pqower steering at all
Acfarm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acfarm Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2017 at 9:45am
If you do not have power steering, the torque limiter could be bad/broken. Any other hydraulic functions work?
~Warren
Post Options Post Options   Thanks (0) Thanks(0)   Quote iluv2694ubaby Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 1:23pm
is there any way to turn the pressure up on the pump it dont seem to be getting enough
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2017 at 9:37pm
You have at least two separate problems here. The transmission (reverse) sounds like an internal problem if the valve body had been closely inspected. Sometimes an experienced eye can see something that the average guy might miss.  The steering is not related to the reverse problem. The steering uses a different pump,filters,and reservoir than the transmission circuit. Remember, the dipstick in the floor of the cab is for transmission,the sight glasses at the rear of the tractor are for the rest of the hydraulics. Does the three point or remote valves even work?
