variable speed control on m2 gleaner
fescue first View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fescue first Quote  Post ReplyReply Direct Link To This Post Topic: variable speed control on m2 gleaner
    Posted: 08 Mar 2017 at 11:08am
variable speed on my m2 does not work all the time and I don't know how to fix it. the unload auger works when it wants too.   help
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 12:05pm
Any other quirks, like volt Guage jumping around, or lights not working during the time that VS and auger aren't working. ...? Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote fescue first Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 12:20pm
not sure on the lights I have taken the hydro apart and cleaned them sometime it helps but not all the time
Post Options Post Options   Thanks (0) Thanks(0)   Quote fescue first Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 12:22pm
volt meter stays around 12 after about an hour the battery goes dead
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 12:35pm
Bad switch, bad solenoid on valve, bad connection in wiring. Does it always slow down, or is it only speeding up?   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote fescue first Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 12:48pm
speeding up
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2017 at 9:09pm
If it always slows down, check #1 solenoid, and wire going to it. Could even be in switch. To speed up, switch has to send current to #! and #? (nor sure of #) to speed up. To slow down current is only sent to #?.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote fescue first Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2017 at 8:32am
thanks
This page was generated in 0.071 seconds.
