any 4x4 Allis tractors that R easy to find parts?
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Topic: any 4x4 Allis tractors that R easy to find parts?
    Posted: 06 Mar 2017 at 6:46am
I was wondering if there are any 4x4 or mfwd Allis Chalmers tractors that parts are readily available and easy to find.  I know the 5020 sure ain't!
I'm not worried about getting going, but rather stopping.  With the wd-45 I had, I would be coming down the steep upper pasture road and if it was wet both rear tires would just lock up and I'd start sliding down the hill.  I had to hit the emergency brake to stop.(drop the loader bucket).  The 7ft bucket on the front stopped me in a hurry...lol
My tires were new on the allis and I had bear paw chains on it...road rougher than heck, but never got really stuck.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 7:34am
I have 2wd's so I can't comment on the MFWD portion but have had good luck with the 6000 series and parts.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 11:34am
I think your problem with the 5020 is it's a small import. You might try to find something more domestic. Of course, the 6000 series is kind of an import too, so that limits you to the 8000 series for a more domestic MFWD.
Or just get a Ford 800/801 series with the Elenco FWD. Lol
Edited by CrestonM - 06 Mar 2017 at 1:07pm
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 12:12pm
Front axle on an 8000 series fwa is a SIGE which I think is from Italy so not totally domestic.
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 2:30pm
If you use your logic all mfwd Allis's would be eliminated. Matter of fact most compact tractors have some foreign influence no matter what brand.
I bought my first 6080 18 years ago and my second 12 years ago and racked up a crap ton of hours they are a very reliable tractor. The motor is one of the best Allis ever offered.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 2:39pm
I meant a 5000 series is nearly 100% a Japanese tractor. The other tractors Allis made have more domestic parts than the 5000 series, and that's what I was getting at about it may be easier to find parts for the larger ones.
I've heard a lot of good things about the 6000 series and up, as well as the 5000 series, it's just finding parts for an older imported tractor is hard, according to the folks that have them. I agree, there isn't much wrong with a 6080, and the 6000 series are great all-around tractors. I guess you're right about all the FWD axles being imports. You are also right, nearly all compact tractors have foreign influence, and I've been told everything JD makes that is smaller than the 9000 series is made overseas. I know the smaller ones like the 1, 2, 3, 4, 5, and 6 series are, but I don't know about the rest.
Edited by CrestonM - 06 Mar 2017 at 2:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 3:39pm
not the good news I was looking for.  Maybe I'll get a backhoe, so I can use it as an anchor if I start to slide down the hill..Smile  ok with the 4x4 debate being settled is there a model that has better braking or one that the engine will hold it back,  the wd45 brakes just locked up and the engine wouldn't hold it back.
I really have no interest in getting a "newer" machine (to expensive) and would prefer to stay with an allis.  Even if I can get a 2wd model to use most of the time, eliminating having to solely rely on the 5020.
 My poor 5020 has dug out the stumps and cleared the brush for 6 acres that use to be all woods to expand our pasture.  It has done all the excavating for our house to be put in and is in the process of digging into the hill side to make a less steep road on our hill side. got about 100yds of the road cut into the road probly almost 1/3rd done with the road, it has hauled all the shale as well.  In case your wonder, it is a pain in the ..... to dig stumps with a loader.  It is also a bit spooky digging a road on a hill side, until ya get a level spot started...at least it's only a 40ft drop if I fall off the hill....lol
Edited by dt1050 - 06 Mar 2017 at 3:42pm
ILGLEANER View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ILGLEANER Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 6:29pm
Every tractor under 100hp of all colors have been made over seas for years . I am thinking back in the 80's there was an article l read stating that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 7:03pm
Maybe renting a new Bobcat / skidloader on tracks with a bucket with teeth may help you more,,, those things are super fast in hydraulics and can do a ton of work in a short time ;; not bashing at all , but an experienced operator could make it all happen fast
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2017 at 8:07pm
Sounds like a 5050 4WD would be just what you need and Import Tractor in Canada has
about any part including front end parts you'd ever need at very reasonable prices.Also lots of parts on ebay.You can see my Oliver 1365
4WD which is a 4 cylinder version of the 3 cylinder 5050.Matter of fact I have a Long 460
which is the 3 cylinder version of that era Fiat although its 2WD.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2017 at 6:28am
I have dreamed of a 5050.  A friends of a friend bought one sight unseen from montana I think and he loved It,  I seen him cutting my friends fields, when he left for lunch I thought about hooking up the trailer and taking the 5050 to my place..ya know just to try it out...lol
I've seen the long's in 4wd, I seen a ford 800 style tractor in 4x4 for sale and didn't even think they made them that way. until this post.  I always thought if I couldn't have an Allis it'd be an Oliver.  like the looks and everybody I new that had them loved em.
I havn't been around tractors until I started farming about 20+ years ago, my family thought I was nuts (probly right).  So I don't know a lot about em, just what I've picked up through the years.
allisrutledge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2017 at 6:44am
There is a 5050 4wd with a loader in the Knoxville Tennessee craigs list. Scott
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2017 at 7:34am
nice looking tractor, Wow with a loader even.  I'm gonna need to save up some $ before getting another machine.  Thanks Scott.  I don't suppose he'll let me test drive it to pa...lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2017 at 10:00am
I don't mind the tractor being an import, just wish parts were a bit more plenty full.  Thanks to all who have responded and thanks to those who have given me a lead on parts for the 5020.  Looks like I'm gonna be making a trip to get the steering pinion, my fix didn't last.  got a bale in to the cows, that's was the main thing that needed done.  Thanks again for helping with an orphaned Allis tractor...Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisrutledge Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2017 at 11:29am
Just tell the wife how much smoother you will fix the driveway and after about a thousand times she will sign the check for you. Before I got a cab tractor I always made sure she was near me when I Blowed my nose after baling hay or any dusty job! Didn't take long till she sugested I get a cab tractor. BINGO I'm sure most of the guys on here could help with ideas that work as well. Scott
PS let's keep this a secret! ok
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2017 at 11:43am
SmileSmile.  Back when we still baled hay, she would probly let me buy an Abrams tank if I would just stop baling hay...lol  she hated it.  The first year I baled she came down to the field in shorts and a tank top...I chuckled, you wearing that...she said it's hot out....after about 5 bales she went in the house to take a shower and change....maybe I'll tell her if I can't get another tractor were gonna start baling hay again...LOL
