AC-CA tranny rebuild
Seabee on AC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Seabee on AC Quote  Post ReplyReply Direct Link To This Post Topic: AC-CA tranny rebuild
    Posted: 05 Mar 2017 at 10:28am
Has anyone here rebuilt a CA tranny...It's the proverbial 3rd gear jumping out....I found a new OEM gear at swap for cheap...But after looking at service manual...It appears I may need more than just a gear change (bushings/shims)...It looks to be a PITA to keep bushing pins in during re-assy....Any help/photos or insight would be much appreciated.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2017 at 10:51am
More than just the gear.  Sloppy bearings and worn shift collars are the problem too.  Fortunately AGCO still carries lots of parts.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2017 at 11:46am
Pay attention of the shim count in each location as you disassemble.  You will probly not need many new parts, if any, if the case is not full of metal shavings/fines/rust.  Take a few pictures as you disassemble. They are not that complicated.    Here is a link to a C transmission.
Well when I try to find the set of pictures with all the gears out I can't find them. This one will give you an idea though.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2017 at 6:06pm
Also check the round ball on the bottom of the shifter lever. Sometimes they get worn and doesn't put the tranny fully in a gear, then it pops out.
