Allis Chalmers 200 - overheating
Justin(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Justin(IN) Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 200 - overheating
    Posted: 20 Feb 2017 at 1:37pm
Hello,
The 200 is overheating just driving down the road. The thermostat was changed recently. Checked the oil and no water in the oil.
Any ideas?
Justin
Edited by Justin(IN) - 20 Feb 2017 at 1:38pm
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 2:15pm
Was it overheating before the thermostat change? Could be possible it got put in upside down. The spring goes towards the engine. Hope its something simple like that.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 2:27pm
Radiator full?
Water pump belt tight?
Radiator fins clean?
Thermostat good?
Radiator flushed good?
Pump good?
Edited by Stan IL&TN - 20 Feb 2017 at 2:28pm
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 8:54pm
Are the belts running to the bottom of fan pulley?
Does it cool down at idle?        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 20 Feb 2017 at 10:17pm
Is the radiator pluged up. Our 200 was doing weird stuff getting hot. One part of the radiator was cold and the other was hot. We took the bottom hose off and back flushed it bunch of times. Took thermostat out flushed out through that way to. Seems to be ok now. Have to put thermostat back in still tho.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2017 at 12:24am
What about the outside fins of the radiator? It doesn't take much crap to fill up the cooling fins and restrict air flow through.
