Gas getting into air cleaner bowl? |
MJR1984
Topic: Gas getting into air cleaner bowl?Posted: 19 Feb 2017 at 10:04am |
Hey I've got a 47 c model with a Marvel Schelber carb and I'm getting fuel in the air cleaner bowl. It also leaks fuel between the carb and the air cleaner. Is it a float issue in the carb.? And would a simple clean out or adjust of the carb fix the issue?
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24892 |
Posted: 19 Feb 2017 at 10:09am |
odds are REAL good the needle valve is NOT closing off, so the carb 'floods'. My D-14 does it....my other D-14 does it...my other ,other D-14 doesn't !
You're best to pull carb off, clean real good, do it again 2-3 times. Also remove gas line, spray brake cleaner(carb cleaner) in it to remove any varnish buildup. It's that crud that can gum up the needle valve/seat area of the carb. Fresh gas from a sweaky celan tank 'melts' the varnish on the inside of the gas line and it gets into the carb... Jay |
Stan IL&TN
Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Posted: 19 Feb 2017 at 10:40am |
Shutting off the gas when the engine is not running is your best bet if and when you can get around to fixing the issue.
1957 WD45 dad's first AC
1968 one-seventy 1956 F40 Ferguson |
MJR1984
Posted: 22 Feb 2017 at 7:30pm |
Ok awesome I took the carb off gonna clean it tomorrow!
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8741 |
Posted: 22 Feb 2017 at 9:30pm |
if I don't shut gas off on my WD,I'm pulling hose off and draining gas to get it started.
