190xt pto question
rudyk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rudyk Quote  Post ReplyReply Direct Link To This Post Topic: 190xt pto question
    Posted: 18 Feb 2017 at 5:18pm
I have a steady drip coming from my pto output.
I have ordered the new seal, what is the best way to remove the old one, and how can I tell if its a shaft which can be reversed from 540 to 1000 rpm
If it cannot be switched, can a different shaft be purchased to make it 1000
Thanks for the help
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2017 at 9:22pm
If it has three bolts on seal housing, it is 540 only.
No you cannot buy a different shaft to make it 1000, needs a lot more parts.
 If it is 540, drain rear end remove three bolts, remove seal hosing and replace seal and orang..
When I was in the shop, I kept a seal housing. Could just switch housings with out draining oil.       MACK
