first weekend with my new WC
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Topic: first weekend with my new WC
    Posted: 06 Jun 2010 at 9:49pm
ok so I got that WC I said about before to the shop....it was locked TIGHT....got it busted loose with some brake fluid, ATF, 2 pipe wrenches, a floor jack, and some grunting....new oil(changed twice), went over everything and stole the carb/fuel line/sediment bowl from the 45 since its down for paint and a jump and I had it running the night I brought it home....about 3 hours time.....here are pics the next day with it at our local spring antique show.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 9:51pm
The reason I look kinda pissy in the first pic and Im hiding in the last is because I was pulling the sediment bowl out of the tank....plugged tight on me AGAIN....lots of rust in the tank and I even sloshed with stones and repeatedly rinsed it out.....gotta work on that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2010 at 9:54pm
I forgot to mention....after having said I brought this home friday night....locked up tight....had it running and put it on the Dyno when I got to the show....33 HP.....and it doesnt smoke at all...runs perfect other than it needs manifold gaskets BAD
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 3:45am
Looks great. Glad you got it going so quick. Hope all turns out well. God Bless.
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 5:39am
Nice looking WC, Benny. Nice work getting it running so quickly. It may take a while to get all that rust out of the gas tank. Good thing your sed bowl is catching it vs letting it get to the carb!
Speaking of carbs...... I wonder if the dyno result has to do with the carb you borrowed from the WD45 - based on my parts books it's a different (likely larger jets) model.
Edited by Dave(inMA) - 07 Jun 2010 at 5:43am
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 6:38am
I knew it was quite a bit bigger but figured since the factory carb was pretty well junk from water I bolted it on....and it works perfectly so Im letting it on there and rebuilding the other one I have for the WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 6:39am
well guys here is the video of the WC's first pull....I think it did great, especially for the shape it was in the night before.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 6:42am
The track wasnt all too great...really sticky....had to run the right side because it was packed the best and I was still pushing dirt with the plate on the sled.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 6:47am
I'll post some more pics up of the other Orange that was there...completely forgot to get video of the sawmill running.....had all Allis Power.....had a WD running the planer and what I believe was an RC running the belt powered sawmill....sure sounded good grunting through a big piece of wood....for you PA guys check it out....google Nittany Antique Machinery Show....there is another in the fall....there are steam engines, hit and miss, anything you can think of, an auction, parts, flea market....this years featured tractor is Ford...2 years ago was AC
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2010 at 11:44am
a question for anyone that watches my video.....does it sound like that WC is turning high enough RPM's or not? I had the local guy that sold AC's since he was a young man(he's 80 now) and he thinks it was fine....it was wide open coming off the line and down the track.
