G Plow
FarmerJohn22 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FarmerJohn22 Quote  Post ReplyReply Direct Link To This Post Topic: G Plow
    Posted: 07 Feb 2017 at 4:58pm
Anybody have any idea of where I can find a coulter for my G plow? Thanks!
1953 CA, 1950 G, 1970 160
Post Options Post Options   Thanks (0) Thanks(0)   Quote FarmerJohn22 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2017 at 5:43pm
Or any other coulter/disk that I can use instead of an original one? I got a plow with my G when I bought it, but it didn't come with a coulter, and I thought it shouldn't be to hard to find a replacement one, but it is proving harder than I thought. Any help would be appreciated.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2017 at 5:53pm
Good luck, those coulters are concave and are used prevent side draft.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2017 at 5:58pm
How big is it? I've seen a lot of smaller 'market garden' discs that might work for you...
been 6 years since I owned the G with plow..memory, is ,um....oh yeh, fading...
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2017 at 6:25pm
It has a square shank mounting shaft that holds in at the proper angle. It can be moved up and down to put the right amount counter draft to the plow.
I've never seen another coulter with a square shaft.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote FarmerJohn22 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2017 at 12:41pm
According to my manual, it is a 14" concave disk coulter. Not sure what the dimensions of the shaft is supposed to be, but I could probably figure it out , except for the length, by measuring the receiver for it on the plow. I think this looks like close to the right disk. Could I just buy something like this with a hub assembly and buy a steel shank of the right dimensions? I would prefer to have an original Allis coulter, but if the only way to get the plow working is to rig up something from new parts, then so be it. What do you guys think?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2017 at 8:08am
Give me a couple of months and I'll measure one for all the dimensions, even the spacing of the rivet holes.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2017 at 8:14am
It's easy enough to turn a round hole into a square one. Just use a good file and some muscle or use a 'hole punch' of the correct size.
If, IF, there was a real market for them, it'd be simple and fast  for a 'fab shop' to punch the holes. Just not worth it for one ( $$$ ??).
Kinda like the front rim adapters I made for my G#2....
Jay
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2017 at 10:18am
In the plows parts book I referenced in AC Plows Parts 101 over in the Knowledge Forum coulters were mostly universal but I don't recall seeing any for the G plow. The universal coulters could be adjusted to fit any model plow frame because it was easy to adjust the height by where the clamp held the shank and the other side of the clamp clamped to the plow beam making it easy to adjust fore and aft. That same universality with a small coulter disk would probably fit the G plow. There might be discussion in the G implement manuals I have posted on my web site.
http://geraldj.networkiowa.com/Trees/Model%20G%20Implement%20Setup%20(TM-3)%20PART%201.pdf   22MB
http://geraldj.networkiowa.com/Trees/Model%20G%20Implement%20Setup%20(TM-3)%20PART%202.pdf   8.6 MB
Gerald J.
allis1221G View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allis1221G Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2017 at 5:24pm
I will have one if the guy don't want the plow. Good guide wheel to.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2017 at 3:35pm
Hey John, the shaft is 1 1/4" square stock, here's what they look like out of the plow.
Just let me know what to measure for you and I'll be happy to do it. I'm only home every other day at the moment, my Mom's not doing well and I spend every other day being with her, but will gladly get you what you need measured at night.
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote FarmerJohn22 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2017 at 7:37pm
Thanks for the pictures and the measurements. Could you tell me the length of the shaft and the concavity of the disk (the distance from the point closest to the shaft to the point farthest away)? Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2017 at 7:48pm
john, see if this helps -
Ford 345C TLB
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Feb 2017 at 9:01pm
Should be easy enough to grind flats on a round shank.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote FarmerJohn22 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2017 at 12:20pm
Thanks for all your help guys. I feel like I have one in my hands, except I can't plow with it! I'll let you know what I end up doing.
Dean(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2017 at 10:08pm
There is  place in Ohio that has G and G plow parts, but I am sorry
that I don't remember the man's name. He had bought out all of
the G parts from another man who was retiring. Does this ring a
bell with any of the forum members?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2017 at 10:10pm
Wasn't there a guy in Fort Wayne Indiana?
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2017 at 10:46pm
Roger VanCamp, a great guy!
Post Options Post Options   Thanks (1) Thanks(1)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Feb 2017 at 10:56pm
you'll have to call Roger, he doesn't do the internet - 260-747-3455
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote FarmerJohn22 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2017 at 9:42pm
Thanks for all the help and advice. I ended up buying one from Roger.
