What Size Tire
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: What Size Tire
    Posted: 16 Jan 2017 at 9:00am
would fit on the front of a C?  I am looking for car tires.  I use it mainly for grass cutting and the 3 rib I have digs up the lawn too much.
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 9:36am
Car Space Saver
I would use something like these donut spares you can order. Width on 125 should be pretty close to a 5.00-15 so those should work and be easier on the grass. The tractor may have had 4.00-15's I think originally but going a little it wider might help it float a little more.
Edited by cpg - 16 Jan 2017 at 9:41am
TL12A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TL12A Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 9:39am
5.00X15 was on many V.W. Beetles and is a perfect fit
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 10:04am
4.00 -15s could have been the original tires back in the day when tire width was the rim width. The tire manufactures changed the width designation to show the maximum width of the tires.
Too wide of a bias ply tire for the rim will make it round like a doughnut, not so much for belted tire.
Besides a car tire there are turf tires. I know in Ag tire handbooks from the big tire makers there is a table of acceptable and preferred rims for all their tires. There should be a similar car and small truck tire handbook with the same table.
Gerald J.
Edited by Gerald J. - 16 Jan 2017 at 10:05am
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 2:11pm
slow down
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 2:21pm
As someone posted the 15 inch tires on older VW's work great.  I have those on a C.  Also, three rib tires that are worn down are fine.  You should be able to fine those cheap.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 6:51pm
Strange!!!!----my C's don't tear up grass!!---first gear mo docs across the yard and never saw a root on top yet! thanks; ac fleet
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2017 at 6:57pm
My B doesn't tear up grass with 3 rib tires on front, and my 8N sure doesn't. It has NDT Jeep tires on it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 9:51am
I use 2nd gear and I have some sharp turns and it's all SAND........
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2017 at 11:18am
roundup?
