Anyone know about an Allis Chalmers trunk?
Anthony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Topic: Anyone know about an Allis Chalmers trunk?
    Posted: 10 Jan 2017 at 1:55pm
Can anyone tell me about this trunk? Fred do you have one of these? I am posting a link to an article written by the guy that used it. You have to scroll down  a bit but you can see his picture, its also a pretty good article on other things Allis Chalmers built. The metal tool box looking thing sits inside the trunk.
https://www.asme.org/getmedia/4a637087-db16-4eb1-8240-e2a1a40e9d8c/67-Hiwassee-Dam.aspx
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 1:56pm
In the download scroll down to the section title Installing the worlds largest pump turbine and you will see a pic of R.S. Dominick
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 3:08pm
There was one on e-bay years ago ,for got what it bought .
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 5:45pm
Were they made by Allis Chalmers, for Allis Chalmers or what? And they guy I bought it from thought it was a tool box for like a mechanic but I wouldnt think a mechanic could carry it loaded with tools. I thought maybe a salesman sample case. Maybe with it having R.S. Dominick on the side it was a engineers box......any thoughts
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 6:42pm
heres one on tractor shed
Allis Trunk
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 9:37pm
I would guess it is a case that Allis bought. The name plate is to show the contents belonged to Allis.. Could have been full of turbine/ pump tools for a job / installation... Probably moved by 2 guys or a small fork truck or cart.
Leesok View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leesok Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 10:20pm
Anthony , I don't know anything about your trunk, I wish I did. That is a great find. I do have one thought tho, bring that to Pawnee!!!
NICKMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NICKMI Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2017 at 8:06am
If you google the guys name on box it looks like he was involved with water turbines for electricity generation
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2017 at 10:37am
Yeah I read that, I pasted a link at the bottom of my first post to that article. For those of you that want to read a good article on Allis history read it, that turbine that Allis built was quite incredible, it acted as a generator turbine one way, but then it could be used to pump water the opposite direction and put water back in the lake!
There is the link again
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2017 at 6:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2017 at 11:35am
OOPS Dave,,,,,,,,,notice the space in between your // and the www.
http://www.asme.org/getmedia/4a637087-db16-4eb1-8240-e2a1a40e9d8c/67-Hiwassee-Dam.aspx
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2017 at 5:44pm
Allis Trunk
For those that don't know, this brass tag is the same one that was used on early AC tractors.  20-35's up through '27 used them for there serial number tag on the dash, '28 and after the serial number was stamped on top of the transmission in front of the shifter.  So most likely this trunk would be dated before '27, unless the factory had a bunch of left over tags they used in later years?  Just thought I'd throw that info out there.
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2017 at 7:16pm
might be a counterfeit, what's the serial number?Wink
