C front pedestal bushings
eighty nine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eighty nine Quote  Post ReplyReply Direct Link To This Post Topic: C front pedestal bushings
    Posted: 06 Jan 2017 at 6:53pm
Does anyone know of a source for the two bushings in the front pedestal for the steering arm shaft? Obsolete from Agco.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2017 at 7:17pm
  GET YOUR MEASUREMENTS   --GO TO YOUR BRG SUPPLY HOUSE
LaJaMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LaJaMe Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 11:50am
Not for a C, but I fixed my WD.  I found a piece of pipe with both of the inside and outside diameters right.  The bolt was still good.  Cheap repair.  Just takes some time.  No slop anymore.  Good luck
saele View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote saele Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 1:15pm
Also check with DJS Tractor Parts, 734-320-3470 or DJSTractorParts.com, they may have what you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 5:11pm
I have 1 Nos bushing. Send me a pm if your still looking
Owner of Matt Scott LLC
http://www.mattscottllc.com/
Post Options Post Options   Thanks (0) Thanks(0)   Quote eighty nine Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2017 at 7:38pm
Took it to local machine shop, they had bushings that will work. Thanks for the replies!
This page was generated in 0.309 seconds.
