B C mower project finished
RLBPA1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RLBPA1 Quote  Post ReplyReply Direct Link To This Post Topic: B C mower project finished
    Posted: 02 Jan 2017 at 3:59pm
Finished today. It's taking up permanent residence on my 39 B. It will be used to mow along my lane and fence rows and will be going to some shows. I need to make a blade cover yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 6:08pm
Nice looking outfit. Stop by your local fire department and see if they have some out of service  2 1/2 or 3 inch fire hose that they would let you have, might cost you a few bucks or a plate of cookies, etc. Split a length of it down one edge and fasten it with bungee cords. Five inch supply would work also and give more coverage.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 6:13pm
Oops...I've only took mine to a show once, but I didn't have a blade cover. Embarrassed
Post Options Post Options   Thanks (0) Thanks(0)   Quote RLBPA1 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 6:17pm
Thanks the fire hose is a great idea.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 6:27pm
my hat comes off to anyone who fixes old implements, takes as much work as doing a tractor!!
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 6:47pm
i put some small chicken wire on mine' with some zip' tie's . worked good' so some little one don't get a finger cut.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 7:17pm
Short chunk of plastic tile or a couple of 1x4 boards bolted together works well too.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 8:42pm
x2! Only I think doing an implement is twice as time consuming, if you do it right!
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 9:38pm
What a GREAT JOB!!!
When I was growing up I sure put enough of them together
Our only  mower till the rotary came along.  Looks good but too many moving parts.
Great looking B too.
Thanks for taking such good care of my favorite
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2017 at 11:12pm
Could you post a pic of your counterbalance spring setup? I need to rig one up for mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RLBPA1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 3:47am
Here is a shot of the spring
Post Options Post Options   Thanks (0) Thanks(0)   Quote RLBPA1 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 4:00am
From the manual
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 9:39am
Perhaps you could get a hydraulic lift for the mower.  If I recall they were a BEAR to lift.
Especially if that is a 7' blade.  Six foot was bad enough.  Five was not all that bad.
Good Luck!
Bill Long
ps:  Again - GREAT JOB!!!
DanC911 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanC911 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2017 at 9:16pm
Fire hose is a great resource but we like bagels at our department.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2017 at 6:56am
What a great job!! Just love the look of a B with a side mower on it.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2017 at 9:59am
Very nice restoration on the b and the sickle bar mower! You can be proud!
