Governor - WD45
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Topic: Governor - WD45
    Posted: 03 Jun 2010 at 10:50am
I'm a governor novice! I've noticed two things about the governor on my WD45:
1. Engine seems to lug down under load rather than governor keeping engine speed where throttle is set. Example: driving from my friend's farm to my place in 4th gear and coming up a moderate hill - engine had enough power to get us up the hill but it sounded like rpm was dropping. Not sure if road speed dropped.
2. If I disconnect the linkage to carb and separate at the joint at front of engine, the the vertical part of the rod running across front of engine rotates about 45-60 degrees toward back of tractor.
Would appreciate your input!
WC, CA, D14, WD45
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 12:22pm
#2  The govenor spring pulls the verticle arm forward and the gov weights bring it back while the eng is running.   When the eng isnt running you can rotate the lever about that far, its normal.
#1  Unhook the linkage to the carb like you did.  Move the throttle lever on the quadrant to wide open throttle.   Now pull the rod forward as far as it will go,  The rod should be just a shade short from going into the hole in the arm.  You can bend the arm if its off, use a vice grip to hold the arm on the bottom and a cresent wrench on the top to bend. If that doesnt help invest in a new govenor spring cause they do get tired.  HTH
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 3:02pm
Lugging down in 4th gear on a hill is normal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 3:08pm
Thanks.....in this case the engine was not running when I disconnected the linkage. The vertical section of the linkage that comes out of the governor case was rotated by a spring (inside the governor?) toward the back of the engine. Haven't tried the test described above with the engine running. Is the rotation with the engine off normal?
WC, CA, D14, WD45
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 3:13pm
You need to do the adjustments with the tractor not running . The no rpms of being off keeps the centrifigal wieghts from trying to hold the rpms down.
