190XT For Sale
Gatordoc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatordoc Quote  Post ReplyReply Direct Link To This Post Topic: 190XT For Sale
    Posted: 02 Jun 2010 at 9:24pm
I have a 1967 190XT Diesel for sale for $3000.  Trying to sell for friend.  If interested PM me and will give you my phone number for more info.uploads/2994/100_0654.JPG
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatordoc Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 6:34pm
Is this priced too high ?
wheatbreeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 6:43pm
What condition is the tractor in
Morley
Farm stuff 8050,6690,175,F2,5050,WD
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 8:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 8:32pm
I wish I could trade a couple of my tractors for that one. I could probably work the brakes on the 190 being a platform type tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatordoc Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2010 at 10:08pm
Well i just came in from tinkering with this tractor and found major problem. The block is cracked behind the injection pump and seeping oil so now the guy that owns it doesn't know what to do. A real deal breaker for trying to sell it. Don't know if it could be welded or epoxyed I know there is a oil galley close by
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2010 at 9:24am
I have a 190 diesel with the same problem.  I took the inj pump off and drilled and taped holes for 1/8 pipe plugs and stitched the crack shut. FDo one hole at a time and overlape the plugs. I dont use the tractor for any heavy work so it holding good.  Check the front motor mounts, they may be broken, mine were.   Also the front wishbone has been broken and repaired. My tractor had a loader on it for years.   Its the 207th 190 made or I wouldve parted it out.  Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jun 2010 at 9:28am
Read this post. I don't know if the 190 used the same engine but anything is possible I hear.
This page was generated in 0.107 seconds.
