Time For a Battery
farminharmon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farminharmon Quote  Post ReplyReply Direct Link To This Post Topic: Time For a Battery
    Posted: 19 Dec 2016 at 2:39pm
Time to replace the battery in the 170 Diesel.  What are your guys' recommendations.  Cold Cranking Amps, Brand, etc.  Most all our tractors and trucks have interstate batteries and we have had pretty good luck out of them.
B110 CA D10II (2)D12III 5040 5050 6080 170
JD5205 Kubota M9000 Kubota M95S
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2016 at 2:51pm
I had an Interstate deep cycle on my dump trailer, got over eight years out of it
WD45 Diesel, RC,CA,IB, B, G, 616, Early B-10, D-10, Terra Tiger, 95G spreader, SC blade
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2016 at 3:24pm
Cold cranking amps aren't everything unless you plan on using it in zero degree weather. Check the cranking amps at 32F also. As for me, I'd go with maximum reserve capacity.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2016 at 5:47pm
The biggest battery that will fit the box and that hasn't sat on the store shelf for more than three or four weeks is the best choice.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2016 at 5:51pm
We sell Deka Batteries. Always had good luck with them. I hear the Interstate's are a good Battery also.
Steve@B&B
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2016 at 10:42pm
 If you want a battery that will out perform all others it would be the Optima batteries. Down side is the price. I tend to buy them online as they are cheaper than buying them in a store. Every tractor I have has a optima battery. You just can't beat the power and longevity. When the lead battery needs to be replaced it gets a Optima. They just don't fail.
Edited by DennisA (IL) - 19 Dec 2016 at 11:35pm
Thanks & God Bless
Dennis
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2016 at 12:11am
last several batteries I bought for the combines and a few tractors were bought from a dude that re-does them. can get big batteries (the powerful ones) for $30. each. so far they've lasted 2&3 years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2016 at 8:35am
I'm with Shameless, tire shop sells redone ones , group 31 for 35 bucks and after 3 years all good , a group 31 will never fit in a 170 box tho ; even tho they need it !
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2016 at 8:55am
I have been using NAPA commercial. A 170/175 really likes a gear reduction starter!
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2016 at 9:06am
An AGM battery will outperform any other of the same size. It will also be the most vibration resistant. Be prepared to pay, though. The Optima noted in an above post is an example of a spiral wound AGM battery. Note that no battery carries a good warranty when used in a tractor as opposed to an automobile.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2016 at 10:09am
Once you use a AGM battery you will probably not go back to the old Standard battery.
Thanks & God Bless
Dennis
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2016 at 10:23am
I've had mixed results with optima batteries. Had them in the boat for the trolling motor. First set lasted 8 years of pretty heavy use, I was ecstatic about that. When I replaced them had heard some negative things  but bought a new set, and starting battery anyway. What I found out is that they moved production to Mexico, (I think). Well the new set didn't make it 2 years. Starting battery 3 I think. Boat now has 3 Interstates in it. Are they the best? I don't know but were half or less money.
I think optima has since moved production back to the states. Quality is probably better, but their not getting anymore of my money!
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2016 at 2:18pm
Yes the optima don't last forever, some don't last as long as other battery
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2016 at 4:52pm
The most powerful battery for its size that I can find is the Odyssey AGM. It is a starting battery that will tolerate deep cycles. It is make by LTV. As far as I know there are three battery manufacturers in the U.S. LTV, Johnson and another I can't recall. Be prepared to shell out $200+. Amazon.com has the best price.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2016 at 6:00pm
Optima used to be good, but after the last buyout, not so much.  JMHO!Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2016 at 7:55pm
They're sold by Interstate Batteries now. I wonder who owns them? I noticed they now carry a 3 year warranty instead of the old 5 year warranty. There are several companies, including Interstate, that sell AGM batteries with a 48 month warranty. Consumer Reports rates the Die Hard and Interstate AGM batteries highly. The Optima is still the most vibration resistant of the bunch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2016 at 9:44pm
The oldest optima I have is going on 10 years. Time will tell on others which are 3 years now.  Have not had any of the troubles listed above in other posts. Hold charge very well and have lots of power.
Thanks & God Bless
Dennis
