WD45 SC Lift Latch Repair |
Dave(inMA)
Joined: 12 Sep 2009 Location: Grafton, MA Points: 2399 |
Topic: WD45 SC Lift Latch RepairPosted: 01 Jun 2010 at 5:26pm |
I am rehabbing a couple of latches that I bought through the Forum. Can someone tell me if the pin in the latch body (part that slides onto the SC arm) to which the latch springs attach is a single pin that goes all the way through? Both ends are broken off, and it appears to be thoroughly rusted into the tube it goes through. Thinking that it is a solid pin, I am trying to remove it using heat and a drive pin. But no joy thus far.
Other suggestions? Anyone have luck drilling them out?
Thanks a lot for any ideas!!
WC, CA, D14, WD45
Larry(OH)
Joined: 11 Sep 2009 Location: Shreve Ohio Points: 1580 |
Posted: 01 Jun 2010 at 9:07pm |
If I understand what your talking about, I believe those are the small twist rivits that press in. mine were broke off, and I drilled most of the way, then was able to get an easy out on the rest and twist it right out |
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact* I can explain it to you, BUT I cannot understand it for you!! |
Dave(inMA)
Posted: 01 Jun 2010 at 9:19pm |
Larry, I have those twist rivets and could drill out enough of the old material to insert them. Thanks.
WC, CA, D14, WD45
Burgie
Joined: 13 Sep 2009 Location: Scottsburg, IN Points: 1192 |
Posted: 02 Jun 2010 at 3:58am |
Yes, It is .
"Burgie"
