Difference between Allis 400 and 500 loader
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Topic: Difference between Allis 400 and 500 loader
    Posted: 16 Nov 2016 at 7:54am
Differences between a 400 loader and a 500 loader mounted on a D17.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 9:13am
A 500 had longer arms, and a bigger center support than the 400, other than that they are identical.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 10:15am
The towers are higher on the 500 loader over the 400....probably 3 to 4 inches taller. The 500 loader on a D-17 uses spacer blocks between the side frames, as the 500 fits 180-185-190-200 series which are wider than a D-17.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 16 Nov 2016 at 10:16am
Pretty sure cylinders are a different  length between the two also. Tracy
