WF fenders??
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Topic: WF fenders??
    Posted: 30 May 2010 at 7:22am
Time to start on the WF and I need fenders. I've been told to get WC by some and WD by others. I compared fenders on my WD45, WC, RC, WF and Speed Patrol and the skins are all identical from what I can tell, just different brackets. Input appreciated.
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 8:04am
It's the backside reinforcement that is different, if you have the old ones from yours then you can use them, otherwise it get's challenging, if you look at the reinforcement you will see what I mean.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 8:32am
I have the old ones. That reinforcing plate appears to be spot welded in?
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 2:21pm
Well then Lonnie, that is most of the battle just get ahold of a nice set of WD WD45 fenders and remove the spot welds and replace with your old reinforcements, and whala WF fenders! I know easier said than done. HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 4:52pm
You do make it sound easy. Thanks
Henry se/k! View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Henry se/k! Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 6:07pm
I filled the wd holes in and used 3/16 plate on back side for reinforcement. Thay will bolt to floor plate where it turns up at front. Looked good consering I had no old fenders
49 WF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 49 WF Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2010 at 9:50pm
My WF fenders are different from my wd's and wc's. The small rib on the inside bottom is not on my WF fenders. It should not be to hard to cut out the rib and fill it smooth.
66 190 GAS,49WF,B,C,37WC,48WF,3WD'S, 66ALLCROP,B1,B10,sbchevy WC
