C Starter same as WC/WD??
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Topic: C Starter same as WC/WD??
    Posted: 29 May 2010 at 10:01am
will a starter from a WD/WC work in a C.  Trying to get finished up and starter bendix (i think) broke.  Starter spins, sounds rough,but does not spin engine.  Thanks
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 10:30am
 No, they don't interchange.
RyanTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RyanTN Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 4:34pm
Larry, I'm not trying to be Mr. Obvious--but have you checked the flywheel for bad teeth?  Very common problem with the B/C's.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2010 at 9:46pm
yep, had starter out tonight and no problems inside.  Definatley the starter bendix is broke.  Put it back in, coasted down the hill and fired up, finished the mowing.  Will be taking starter to shop for rebuild/repair
