190 Rear axle pusher bolts
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: 190 Rear axle pusher bolts
    Posted: 07 Nov 2016 at 9:04pm
I read through the earlier posts about how to remove 190XT wheel centers from the wedges.  I have not been able to get my hands on any authentic pusher bolts locally, nor do I want to pay an outrageous price for something I am probably only going to use once.
It looks like I can fit a piece of plate steel between the wedge and center and thread 3 bolts against it.  Here is my question:  Does any one know the thread type in the wedge?  A regular national coarse thread bolt only seems to turn in one round.  Yes, I did clean the threads first.  In the earlier posts, Mack mentioned that the threads were different, but did not give details.
I would appreciate more insight about these things.  Thanks!
hillmonkey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hillmonkey Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2016 at 9:27pm
http://www.allischalmers.com/forum/forum_posts.asp?TID=106054&title=190-rear-wheel-removal
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2016 at 9:53pm
190 has a standard 3/4 course thread. The 7010- 4w305 have the odd threads.
 If you put a steel plate behind wedge, use the thickest steel plate that will go in and use grade 8 bolts. Also oil threads and end of bolts.     MACK
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 6:00am
I tried a plate once and ended up punching an ugly hole in the plate and took out the first thread in the wheel. No real harm but I then went and bought a set of pusher bolts from AGCO. That was 20 years ago and they were only something like $3 or $4 a bolt back then.
Wink
I am a Russian Bot
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2016 at 8:06am
I had to take a hub off the D19 years ago think I used grade 8 bolts as a pusher with sightly sharpened ends and a size smaller nut to press with and an impact.The impact jarring everything made them come right loose.
