d-17 hydralic lift pin removal
IHSMOKE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IHSMOKE Quote  Post ReplyReply Direct Link To This Post Topic: d-17 hydralic lift pin removal
    Posted: 06 Nov 2016 at 9:23pm
any tips to help a newbie to get the rear rockshaft off to fix leaking hydr. cylinder hose ....what does it take to get that pin out of the right axle housing ...remove brake rod too?? TIA IHSMOKE
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2016 at 9:35pm
Remove brake rod and loosen setscrews under pin.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2016 at 9:36pm
I seldom pulled that pin. I removed the lift arm housing and pulled the rod out of the cylinders barrel.
