All crop 66 corn head
AllisandGleaner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Topic: All crop 66 corn head
    Posted: 24 Oct 2016 at 7:41pm
Need help finding out how a corn head hooks up in place of the grain head pics would be perfect
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 8:38pm
 The corn head mounts and pivots at the same place as the grain head. The drive for the head is a PTO shaft that attaches to the shaft at the end of the gearbox.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 9:05pm
Well I'm not sure if I have all my parts
Joe Graunke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe Graunke Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 9:14pm
Do you have the feeder house?
Joe
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Oct 2016 at 10:40pm
 There are a lot of parts that get added when you switch over to a corn head. I min of 2 dozen parts.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 6:12am
Are you there any parts for sale for them
Chad (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 12:47pm
Sorry I don't have more pictures right now but here is a top look at the head on a 66.  We took the corn head off a different machine and installed it on this combine.  You need:
the sheet metal for the throat to dump the corn into the cylinder, some braces to accommodate the added stress from the weight, switch the entire cylinder assembly from one machine to another if possible (saves taking one apart & putting it back together), and some additional stuff like different concave bars & pan liner, canvas curtain behind cylinder above straw rack, stalk protection plate under the clean grain elevator, and heavier spring loaded lift mechanism.  There are only two pivot bolts that hold the header to the combine but there are many other pieces that would need to be switched.
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2016 at 10:55pm
Here are a few pictures.
This is the parts to mount the head.
 This shows where the part attaches to the corn head.
 Bracing
PTO shaft to the head
Tailings sieve
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 6:33am
Would it be possible for someone to make copies of that stuff
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 7:38am
 What all do you need? Do you have the cylinder bars and concave bars? they are different as well. Also the concave insert is needed to beef up the concave as well as 2 extra pieces of angle iron under the concave.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 6:25pm
I will be honest all I have is the corn head and that's it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2016 at 11:30pm
 That's a ruff deal. Any way you could get parts from where you got the head?
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2016 at 6:06am
I bought the head from an old man where I got it from it had not moved for 40 plus years. I asked if he had the redder house shout and he said what I hot was all he got when he bought it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 9:59am
 Make the parts to mount the head should be easy. If you can find a PTO with a smaller I.D. you can take it to a machining shop and have them thread it. The feeder house is just sheet metal that is supported with angle. May not be factory but can get it working.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisandGleaner Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2016 at 7:14pm
That might work only if I had one to go by
