Does a D15 Crank pulley come ready for hyd. pump
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: Does a D15 Crank pulley come ready for hyd. pump
    Posted: 27 May 2010 at 6:22am
Sold the loader off of my D15 complete with the hyd. pump that runs off of the crank pulley.  Was wondering if the pulley that comes on a d15 has the bolt hole locations for the hyd. pump shaft already or is that something that had to be changed when putting a loader with live hyd. pump on?  Just trying to find out for the new owner so that I know if we have to swap crankshaft pulleys or not.  Thanks for any help.
FredW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredW Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2010 at 6:55am
The pulley is drilled and tapped for adapter to drive pump. Fred
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredW Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2010 at 6:58am
I should also mention you can purchase a new adapter easier than remove yours and if you need a name for the company I have it somewhere. Fred
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2010 at 8:44am
Thanks Fred.  If you have that info, that would be great.  I told the new owner it might be a good idea to put new rubber grommets by the hyd. pump as well as long as it is apart.  Might be able to get them from the same place
This page was generated in 0.079 seconds.
