hei ready for plug wires
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Topic: hei ready for plug wires
    Posted: 26 May 2010 at 7:03pm
Edited by mlpankey - 26 May 2010 at 7:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 7:05pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 7:30pm
Ready to build them for other pullers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 11:37pm
How well do they fit under the hood?
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2010 at 5:23am
MLP, Let's have a video of the engine running, betcha it's going to sound real good!
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2010 at 6:15am
Looks good!
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2010 at 6:17am
Chris I am hoping to get to the running video soon .
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2010 at 6:22am
  I dont think the wd hood will be a promblem distributor is still below valve cover . The wd ,wc,wd45 hoods shape exposes the valve cover in the area where the distributor is located.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2010 at 12:51pm
Now that I think about it, I'll bet you're right. Might be a problem for a B,C, and CA though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2010 at 3:41pm
I dont know I have a ca and a d14 that I want to fix two for and let the four pin gm module do the firing duties instead of the msd 7 box. I can shorten it up some more if needed.
Edited by mlpankey - 27 May 2010 at 3:45pm
