wd45 hand clutch stuck
sling-it View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sling-it Quote  Post ReplyReply Direct Link To This Post Topic: wd45 hand clutch stuck
    Posted: 08 Oct 2016 at 9:54pm
I know it's been discussed here before, but I can't find it.
Is there anything I can do to make it easier to break this thing loose? She's been parked about a year. I get to pulling a bush, didn't want to burn the clutch, so I popped the hand clutch forward and dumped the foot clutch, and proceeded to pick the front wheels off the ground about a foot. That wasn't supposed to happen LOL
I was sure. once I figured out it was stuck, that putting that much torque on her she'd break loose. I was obviously wrong.
Any advice? Additives? Suggestions?
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2016 at 11:12pm
First of all, is there a reason it would be stuck? Has it been sitting for a while and if so was the hand clutch engaged/pulled back? That is a no-no in storage anyway, but with it running in an oil bath it would be awfully hard to get them stuck together unless moisture got in and rusted them or the engagement arms. Take the battery box off and the cover over the clutch and look in there. If you don't see any broken parts and brass collar isn't worn and disengages with lever try to take a big flat screwdriver and gently tap in between the plates to see if they separate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2016 at 8:05am
Sounds like good advice from Bill.
I have never seen one stuck.
Please describe the problem in some more detail.
1. So if you move the hand clutch lever forward does it make a snapping sound (going over center)?
2. If the hand clutch is in the forward position the tractor will still move when placed in gear and the foot clutch is allowed to come back?
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2016 at 8:30am
Remove the battery box and the clutch cover that's under it. They run in oil and should never be stuck unless it was ran out of oil. If you don't see any broken parts you could remove the six bolts holding the clutch pressure plate on. Make sure you save the shims. Take a small pry bar and seperate the plates you only have a small amount of room but with the clutch disengaged there should be free play between all the plates.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2016 at 8:47am
Could be the snap ring has fallen off. Mine did that and the clutch was constantly engaged. I had a few posts on it with pictures you can search for.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote sling-it Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2016 at 9:25am
It very well could be low on oil. She's leaking some, and the last time I used her was for a bunch of blade work...and yes, she sat engaged. I've never had this happen before. I'll start storing disengaged from now on.
The clutch arm works as normal. Snapping forward and back, it just doesn't do what it's supposed to do.
I'll check the oil level and let it sit for a while disengaged. If that doesn't cut it, I'll pull the plate and get a closer look.
Thanks for the advice!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2016 at 8:15pm
Hi,
 I had one WD where the two piece brass collar had worn out and the clutch was engaged all the time. Clutch lever would move but the brass collar was not functioning. Sounds like you will need to remove the battery box and cover, and check it out.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2016 at 9:49pm
bet you will find the splines and the plates all rusted together in one big blob.....
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 7:26am
As long as the torque tube is full of oil there's no need to store with the clutch disengaged. I bet 90% of WD's are sitting right now engaged. Key is to have full of oil and no water in it.
corbinstein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corbinstein Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 7:28am
Mine is...
Jackmaxx12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jackmaxx12 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 7:34am
Hello
         Thanks to using forums site ,yours question recording subject I no knowledge in this subject .
So please help nearest shop and yours friend . Thank   you
If anybody know about knowledge basic java please  click this site .
Thanks you.http://www.basicjava.com.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2016 at 9:47am
Jackmaxx12 reported
