Thermostat spring size
Bensjamming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Topic: Thermostat spring size
    Posted: 30 Sep 2016 at 8:17pm
Does anyone have a spring for the thermostat that they could measure the diameter and the length for me? I'm missing mine but have a spring for a moped clutch that looks to be about the right size. Is that it's only purpose is to hold the thermostat in place?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2016 at 8:25pm
Knowing which engine on what tractor would help, loads...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2016 at 8:52pm
Lol I suppose it would. Sorry. It's for a 1942 model c with the standard gas engine.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2016 at 9:03pm
I think it would be best to just buy a new thermostat, they do not cost that much.
Norm Meinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2016 at 9:46pm
I sell new springs with or without the thermostat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2016 at 10:36pm
I plan on getting a new thermostat. Just seeing if the spring i have laying around would work or not. If it just keeps the thermostat in place then as long as it's close to the right diameter to go over the thermostat flange and is long enough to apply sufficient pressure then I'm thinking it will work. If its the right size then I'll be ordering one.
I don't understand why they would put a spring in there to begin with. Wouldn't just a normal housing that holds the thermostat in place be fine or is there something I'm missing about what the spring does?
OnlyAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OnlyAC Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2018 at 11:02am
Did you ever find the spring? If so where?  I need one for a WD45 and am having trouble locating it.
AC list: B-10 | B-112 | WC | WD45 | D12 | D14 high-crop | D17 gas | D17 Diesel | D19 gas | D19 Diesel | 185 |
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2018 at 11:05am
Norm Meinert has them and so does Jim Danforth.  both site sponsors
ooops, this would be for model C.  wd45 doesn't use a spring
Edited by CAL(KS) - 11 May 2018 at 11:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote OnlyAC Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2018 at 11:09am
I sent an email to oktractor and never heard back.  Tried calling Norm and all I got was an answering machine with a computer recorded standard message. Wasn't even sure I had the right number.  Guess I'll try again.  Thanks!
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2018 at 11:36am
I made a 2 inch spring from Ace work.
1951 B
