Help needed - 5030 Hydraulics
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Topic: Help needed - 5030 Hydraulics
    Posted: 24 May 2010 at 7:17am
My little ever-ready bunny has a problem. I went to my garden area with a 5' 3pt bush hog and everything was fine. Cleaned up around garden and drove back to barn - about 1/2 mile. Was in a hurry and drove faster than usual -- some road, some gravel lane. Back at barn, shut it off and lowered bush hog. Ate lunch and went to work around barn area. Started the tractor and when I moved the lift lever, absolutely nothing happened. The lever seems to be tight on the shaft and the hydraulic level is full. Any ideas as to what has happened and how to fix would be appreciated. Thanks - Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 7:38am
Oh, forgot to say that it's my wife's tractor which she loves. She was to one to jump on it to work when it wouldn't lift -- guess who is in the dog house -- but I really didn't do anything , honest.  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2010 at 7:13am
Still looking for any help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 8:21am
Still looking for any help.
EricPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 9:08am
maybe the raise/lower speed adjustment knob under the seat vibrated all the way closed ?
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2010 at 10:55am
You need to check the output of the pump...it is driven from the engine.  Could be anything from lost its 'prime' to a broken shaft.  Maybe even a plugged inlet filter.  There is a tube nut on the pressure line under the seat that you could remove and check for flow to start with.
