WD valve clatter
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Topic: WD valve clatter
    Posted: 23 May 2010 at 8:08pm
The valve train on my WD has become noisy. Valves properly adjusted. Put in 50W oil. Valves oiling properly. Still noisy. Rocker arm shaft not excessively worn.  Is it correct to assume the valve guides are worn and causing the noise? Will it hurt anything to run it this way?  Brush hogging season coming up and I would like to wait until fall to fix it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 8:24pm
Better check the lash again. Loose guides don't make noise. Check for bent push rods.
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 8:26pm
Do you care to take time to tell how you properly adjusted them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 9:38pm
Removed spark plugs. Turned each cyl to TDC with hand crank. Set clearance at 0.014" cold.  Replaced plugs, ran engine until it reached operating temp.....160 deg. Removed spark plugs. Set clearance at 0.012". Blocked air flow from fan with cardboard.  Ran engine. Stuck feeler gauge between each valve and rocker.  Snug feeling when moving feeler gauge. All suggestions/comments appreciated............O_O.
Edited by Osage_Orange - 23 May 2010 at 9:40pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 6:40am
[QUOTE=Osage_Orange]Removed spark plugs. Turned each cyl to TDC with hand crank. Set clearance at 0.014" cold.  Replaced plugs, ran engine until it reached operating temp.....160 deg. Removed spark plugs. Set clearance at 0.012". Blocked air flow from fan with cardboard.  Ran engine. Stuck feeler gauge between each valve and rocker.  Snug feeling when moving feeler gauge. All suggestions/comments  quote oo           Thats what  i figured the correct way to set valves is  to adjust the intake valve as its exhaust valve just starts downward to open  then you adjust the exhaust valve with the intake valve all the way down just starting upward to close. That ensures your on the heel off the cam everytime.
Edited by mlpankey - 24 May 2010 at 7:39am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 7:20am
Thanks ml.  I'll follow up & let you know how it worked out..........O_O
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 7:38am
It put my post in with your statement i dont know  what the oo meant sorry about it tagging on yours . maybe me editing will help . thanks dave for the heads up.
Good View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Good Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 8:53am
Make sure your not losing oil out the corks on each end of the rocker shaft while your in there.but sounds like you a little to loose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 9:05am
ml: the O_O is just my shorthand for Osage_Orange.  Think I'll quit doing it....can see how it might introduce confusion.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 1:36pm
Proper way to set the valve clearance becomes an opinion thing. When the piston is at TDC on its compression stroke the cam should be ground so that you would have the widest opening between the valve and rocker arm. The cam is ground with the same distance away from the valve until you start up the valve opening lobe.  The proper way to set valve clearance as I was instructed back in the 1950's by an Oliver dealer repair shop was to set with the engine running at idle. When people would tell me they set the valve clearance with out the engine running I thought for many years they didn't know what they were doing.  Over the years I figured out that there is more than one way to do things correct. What you did would be correct if you were in fact on the compression stroke. What planky told you it correct also if you chose to do so.
If you look at the cam shaft when it is in your position or at what planky said you will find the same distance if the cam is not wore off in some places.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 4:29pm
If you ever  run into a dual pattern camshaft  to my knowledge the only way to adjust is the way lunati and comp cams publishes which is the way I recommended. I do all cams this way it takes out the wondering on other peoples cams if its a single or dual pattern cam but yes single pattern cams can be done different ways .although when attempting to adjust as allis recomends doing four valves at a time with no.1 pison at tdc then plcing no.4 piston at tdc on reground pulling cams i found my lash to be all over the place . plus most automotive performance oriented tunners do it the lunati and comp published way also.
Edited by mlpankey - 24 May 2010 at 4:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 8:26pm
Update:
1) found three bent pushrods. approx 0.005" to 0.007"  when laid on a "known to be flat surface" and rolled.  straightened and reinstalled.  How does a pushrod get bent? Can I expect them to bend again?
2) re-adjusted valves by ml's method. Variance between my settings using TDC method and his were about 0.001", sometimes +, sometimes -.
3) plugs in end of rocker shaft ok, no leaks.
4) good oil flow to rocker arms & pushrods.
5) reassembled engine and brush hogged for about two hours.  All ok.
Engine runs slightly quieter.  Maybe I'm expecting too much.  Gonna try to run it all summer and go from there.  Good oil pressure (about half scale on AC gauge).  If camshaft bearings were worn, wouldn't it be more of a knock like a crankshaft bearing too loose?
Thanks to all for the help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 9:00pm
Glad you got it . Bent Push rods can be from valves tending to stick in months of non usage to improper lash even piston to valve . However usually those tractors have more than plenty piston to valve clearance .Not pushing improper lash I guess I should explain lash could be set proper but a rocker arm loosening bent one on mine once. I think you have it and can use it all season with out worry . Again nothing like satisfaction in a accomplishment .
