B Oil Filter Experiment
 Post Reply Post Reply Page  123 5>
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: B Oil Filter Experiment
    Posted: 08 Sep 2016 at 11:14am
I saw this and thought it was interesting.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2016 at 11:56am
Very interesting.
Can't fix stupid
peterh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peterh Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2016 at 2:06pm
I use the Fram C-159 in both of mine. never had any problems. Always remember to pour some clean oil into the filter and let it soak in before attaching it.
1947 C, 1949 B, 195? CA
60 series cultivator
fertilizer side dresser
2 bottom snap coupler plow
1 bottom plow, Cole planter
Tcmtech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2016 at 2:42pm
SO which is better for the engine?
The low surface area one that holds back more oil pressure or the high surface area one that lets more though but reduces engine oil pressure?
And also why are their filter system not in series with the pump to keep any crud from getting to the load bearing rotating parts instead of a bypass to everything?   Question
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2016 at 6:49pm
Bypass filters were the standard before good filters were invented to handle the full flow of all the oil from the pump. Cleaning was a side effect of the bypass filter.
Some of the pleated bypass filters have lowered the oil pressure on Allis engines enough to wreck the engines. The Fram C159 filter is safe for these engines, others are deadly.
Gerald J.
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2016 at 8:20pm
These Wix/NAPA/Carquest filters with the rubber boot inside were made for a short time in the early 2000's. They caused the AC engines to lose oil pressure and were recalled at least 10 years ago. If someone trys to sell you one don't buy it. The new Wix # for the correct filter for the older AC is 57011 Napa 7011. We are a Wix distributor where I work and we got a case of those when they came out and when I tried one my pressure went down and I wouldn't sell any of them. You buy the Wix/NAPA filters with the new #s and they work just like the originals.JP
'59 D14 '68 170 Diesel '81 7020 40 All Crop
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2016 at 8:40pm
Very nicely written and analyized. Sic) That took quite a bit of time and thanks for sharing.
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2016 at 9:03pm
That's a nice experiment but why not just buy the factory filter for the $7 it costs
There are 3 ways to do job GOOD, FAST, CHEAP. YOU MAY CHOOSE 2. If its FAST & CHEAP it won't be GOOD, if it's GOOD & CHEAP it won't be FAST, and if its GOOD & FAST it won't be CHEAP!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2016 at 9:32pm
For many that's like asking them why they don't get the tires on their trailers balanced
Which usually lead to this sort of reply.
"Cripes. I just spent $1500 for 6 new tires you really think I'm gonna spend $12 more to have them balanced?  Heck no! I'm gonna shake and then  cuss about it everytime I use it for the next decade csu you just don't balance trailer tires."
So do you really think that guy's gonna spend $7 for the right filter when he can get the wrong one that fits but doesn't work correctly for $5?   Tongue
Just the thought of that would make my Grandpa role over in his grave if it wasn't for the fact he was cremated.Wacko
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2016 at 9:45pm
These old type filters never did much filtering. If a guy would plug the filter off and let the engine have all the oil, change oil more often, the engine might even run longer .    MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2016 at 10:04pm
Everybody don't have an Agco dealer down the street.JP
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2016 at 10:06pm
there is no " factory OEM filter"..........AS Jack said, WIX tried to redesign the bypass filter about 10-15 years ago and it did not have enough back pressure and caused low oil pressure and resulted in several motor failures... You can buy the new WIX, NAPA, FRAM, Baldwin, or any other as long as it is a stuffed cotton design that is packed tight and you have the original 1/4 inch tube up the center. This design is made to bleed off 15% of the oil and filter it and dump back to sump. The other 85% of the oil goes to the motor and is sprayed on the bearings and gear train , cam, lifters, valves, etc.. A GOOD engine will maintain about 15 psi on the gauge... a worn engine may run down to 5-10 psi .... you start having trouble with oil feed if your running 5 psi.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2016 at 11:09pm
So why not just change the little orifice to a smaller one and let it do all the oil flow limiting?
Seems like that would be a lot simpler than trying to find a filter with just the right back pressure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2016 at 11:23pm
I say why not get a stiffer relief spring...
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 6:50am
I dough the relief valve ever opens on these systems.    MACK
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 7:17am
The AGCO filters were no good at that same time period. Same manufacturer I guess.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 7:32am
 Imagine a garden hose with a Tee so you have 4 ends. Hook one to the hydrant, put your relief valve with your stiffer spring to the second end, and run the third end to the filter base. Your 4th is just for a pressure gauge.
 With the proper filter on the base, turn on the water and look at say 15 psi on the gauge. The relief valve was basically a safety deal so you don't blow out the oil filter can.  Now, remove the filter and see what happens to the pressure at the gauge. Yes, it WILL go to 0 psi!
 That is exactly what happens with those WIX filters, no restriction in the filter makes for no pressure to the gauge. It don't matter if you plug the relief valve off completely, the fluid will go to easiest route, right thru the filter.
 If you went to AGCO in 2002, and paid extra for a filter, you most likely got a "new" junk WIX which was the cause of many engine overhauls that wouldn't have been needed with the proper restriction in the filter. Around 2002, I had our purchasing agent at my work order a filter from NAPA when he had a big order of things for the shop. Luckily I had read on this forum about the junk filters being sold. That filter got sent back.
Edited by CTuckerNWIL - 09 Sep 2016 at 7:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 7:36am
I don't know what you consider "factory" since AGCO was selling the JUNK Wix filters at the time!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 9:59am
Oh sure, they'll answer your question.  Tongue
Now if you put a properly sized restrictor orifice on the connection between the aforementioned Tee that would choke off the flow to the filter your relief valve concept works just fine and solves the whole who's filter is the best one' debate being any filter of any size would now work and the system would run at whatever pressure the relief valve sets it at. Embarrassed
Yea I know, 'but, but, but... the stock orifice is ~1/16" dia and I don't have a smaller drill bit that that so I can't make a new one or solder/braze the old one shut and redrill smaller'.
Oh well, it's a shame world has ever been able to mass manufacture a drill bit smaller than 1/16" huh?  So doing an online search for such a drill bit the size of a needle, a 'needle drill bit' or 'micro drill bit' would be a fitting name such things if they existed, would be pointless? Cry  Tongue
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 10:14am
The bypass circuit was engineered to put a certain percent of oil through the filter. The size of the restrictor was engineered for a certain design of oil filter. Sure you can put a smaller restrictor on, but this is at the expense of how much oil you are filtering. A stiffer relief spring will do nothing. The relief should only come into play when the filter circuit is clogged.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 11:36am
I look at it purely from an engineering stand point of X amount of restriction is needed which relates directly to Y amount of oil being able to flow through the circuit.
Going by  the numbers for standard orifice flow rate Vs pressure for common oils  at 15 PSI ~ 1/2 a GPM flows through a 1/16" dia orifice.
The problem I see is that with what 1/16" port open to free flow due to an unrestricted filter design  the pump and engine side of the orifice pressure drops to ~7 PSI which means that the system only has about .25 GPM of flow rate it can dedicate to feeding filter circuit.
To get that flow rate a second restriction beyond the 1/16" orifice (filter side)  is required which by the numbers works out to being ~ .045" in dia which would be the equivalent orifice value the filter has to emulate to get that .25 or less GPM number so that the full 15 PSI pump pressure limited by the bypass valve and spring assy can be achieved.
So given that just put in a .045" or slightly smaller dia orifice in place of the  1/16" (.0625") one and forget about the filter needing to supply any degree of restriction. End flow rate through the filter is the same, filtering is the same and the oil pressure stays up where it needs to be.
That's how I see this based on rough flow rate Vs pressure numbers from here,  http://www.efunda.com/formulae/fluids/calc_orifice_flowmeter.cfm#calc ,
and ones that have been posted on this thread.
That's how an engineer see's this issue.  It's not about the filters.  It's about the required restriction needed to match the system parameters in play which since filter design changed the orifice size need to change to match it to achieve the same end results given an unchanged input pressure or increase in flow from the pump.
Edited by Tcmtech - 09 Sep 2016 at 11:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 12:19pm
It's about the filter in that the filter itself provides some of the restriction. Too little restriction means more oil through the filter circuit and not enough (if any) oil pressure to get to the top of the engine.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 12:26pm
I'm glad I'm converting over my WD45 to a full flow/filtration system
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 12:28pm
I disagree.
I have both 10 micron filters and large 20 mesh screen filters that neither provide any degree of restriction at low flow rates yet obviously the 10 micron has nearly 100 times finer filtering ability.
My point is a filter does not have to have high restriction to have very fine and good filtering ratings.
In the case of the tractor oil system once the flow rate limitation is met (combined  equivalent restriction) the filter restriction itself is irrelevant.
To me it's no different that adding restoring series in an electrical circuit.
Say a 15 volt source needs a steady .25 amp draw it doesn't matter if two resistors of 30 ohms or 20 and 40 or 10 and 50 combine to make the 60 ohm resistance or whether one 60 ohm resistor is used.    The required current draw at that specific voltage is being met.
Edited by Tcmtech - 09 Sep 2016 at 12:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 12:30pm
But what's the fitler forward pressure drop and micron rating?   ShockedTongue
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 12:33pm
Depends on the filter material. I really doubt you are going to get 10 microns from cotton.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 3:17pm
re: ...
...cause up here they cost 24 Canucks !!
and I need 4 of them, sigh....
I'll gladly pay $7 a piece though !!
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 3:49pm
why are you trying to modify the filter, change orifices and redesign the system ?  WIX tried that and failed... for the past 70 YEARS you could buy a FRAM or BALDWIN or others that was built to FACTORY SPEC and works fine......... If you want to buy a 15 year old CRAP Wix filter, change the orifice and redesign the AC oil system, that's fine... but WHY ??? I would guess 999 out of 1000 people don't care to do that.  Could be done by anyone, but WHY BOTHER......... What they had for 70 years WORKS.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 4:21pm
The restriction IS properly sized to let a certain amount of oil pass through the filter. Closing the restriction down may give you more pressure at the gauge, but will  filter less oil and do NOTHING for the engine except run dirtier oil thru it.  The only pressure needed in the CE engine, is to get oil up to the top of the head so it can leak out through the rocker arm and lube the top end.
 Here is Dick's description of the oiling system.
" Oil pressure is not made at the bearings on this engine. The bearings can all be shot and still have full pressure. The relief valve is in the stem of the oil pump leading to the center of the camshaft. No pressure is built in the camshaft. The cam bearings and main bearings are oiled by the spinning of the cam shaft forcing the oil out holes in the camshaft by centrifugal force. The oil pipe you see leading to the filter and head is where the pressure is built between the relief valve and the resistance thru the oil filter. The spinning of the crankshaft causes the little funnels in the top of the rods to catch oil being spun out of the camshaft holes that are in line with the rods. The oil is forced into the rod bearings thru centrifugal force. That be the oil systems operation in this engine."
 Now as far as drill bits, you CAN buy just about any size you want as long as it's bigger than .013 of an inch. http://bobmay.astronomy.net/misc/drillchart.htm
I've drilled HUNDREDS of 1 mm holes in parts in a CNC lathe.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2016 at 4:35pm
LOL   LOL   LOL
This page was generated in 0.150 seconds.
