1950 b carb
Russ-mid MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-mid MI Quote  Post ReplyReply Direct Link To This Post Topic: 1950 b carb
    Posted: 22 May 2010 at 12:56pm
I have a 1950 B. It hasn't been started in a few years. the carb is gummed up with a shellac type stuff. What is the best thing to clean it in or let in soak in? Thanks. Russ.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2010 at 1:40pm
I drop them in pail of NAPA carburetor cleaner over night after removing the jets and small parts like float and seat. The stuff in spray cans just does not do it well. I have read in tractor related posts on different sites where they boil the carburetors in water to remove the crud first. I have not done this but have been thinking of trying it. Problem is Dixie is not out of the house when I am home long enough to get the water up to boiling. After using the oven to dry small painted parts I get the idea that she don't trust me home alone. I didn't realize that the paint odor lasted that long when I was not married.  (:^D
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 10:00am
As Dick mentioned, the Napa carb cleaner works quite well. A great way to pick-up where the Napa cleaner left off is to glassbead it after the dip. Not everyone owns a glassbeader, but cleaning it out with a small wire brush will help. A good washing out with Brakekleen will get rid of the dip pail residue before the rebuild parts are installed...
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-mid MI Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 2:32pm
Thanks for the info. I got a gallon of the NAPA cleaner and put it in this AM. Will probably leave it in all night. It is amazing how much crud can build up on and in it.
