175 3 point capacity
pdh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdh Quote  Post ReplyReply Direct Link To This Post Topic: 175 3 point capacity
    Posted: 22 Aug 2016 at 8:43pm
How much weight is "too much" for a mounted implement on a 175 3 point? Will it handle 1250 pounds?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2016 at 8:45pm
I guess it depends on how far out it hangs from the 3pt arms.
ctbowles 58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles 58 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2016 at 8:51pm
I had a 4 bottom 70s series plow on mine and It lifted it just fine. don't know what it weighted but I am sure it was 1000 lbs +.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2016 at 10:04pm
If it can pick it up, it isn't too much.
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2016 at 4:15am
I carried a fully loaded 8-row wide mounted planter on my 180 for years. handled it just fine, i'm sure there wouldn't be that much difference between the 175, and 180!
pdh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdh Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2016 at 4:40am
Thanks, all.
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2016 at 6:45am
If the 180 is a 6 cyclinder there is some difference.  I have a 175 no weights and a 185 no weights on front.  We have a 9' cut disc mower and the 185 handles it fine but the 175 is a bit light in the front when you lift it.  If I had weights it would handle it fine as far as picking it up and running it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2016 at 7:10am
The lifting "power" between the two tractors ( as long as they have the same type of lift cylinders) is identical. Front end weight has to be added as needed.
pdh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdh Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2016 at 7:13am
My 175 has suitcase weights. I am trying to determine whether it would be enough tractor for a "fill in and re-plant" planter - 4 row 30 JD 7100.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2016 at 9:15am
more than enough! my 180 has one weight on it in front. but I also have a platform made to fit on the front of it, that's where I carry extra seed bags. it'll hold 8-10 bags of seed. of course as I use the seed it'll get lighter, but it never raised the front end off the ground while the planter was on it. even when the boxes were full.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2016 at 11:12am
I pick up a 1700# bushhog with just suitcase weights on my early 175D. Later model needs suitcase weights and loaded 9.5L-15's to keep the front end down due to the hollow front casting required for the front mount hydraulic pump....
ALLIS EXPRESS!
This year:
