180 gas to diesel
jw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jw Quote  Post ReplyReply Direct Link To This Post Topic: 180 gas to diesel
    Posted: 20 May 2010 at 8:01pm
i have a 180 gas tractor and an opportunity to get a running 190xt motor .Question is will a 190xt motor fit in the 180 without much modification
niel ev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2010 at 10:13am
No you'll have to change the fuel tank also unless your gas tank has a plug in the top to put the fuel return to and also the thottle linkage has to be changed I think . We have a gas combine engine for 1200 if that would help Niel
jw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jw Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 8:36pm
thanks anway neil but my gas motor runs fine would like to put the bigger diesel in place of .
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2010 at 8:33am
where are you located? I have a 180 diesel engine, but need a 190XT diesel. Could save me and you from having to swap alot of parts from one engine to the other.
