c transmisson question
Richmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richmar Quote  Post ReplyReply Direct Link To This Post Topic: c transmisson question
    Posted: 25 Jul 2016 at 9:12am
I have a C tractor that will not stay in third.  What do you think I need to look for to correct this problem?  I need to hold the shift lever to keep it in gear.  Any help  would appreciated.
Thank You
Richmar
Bonny Lad Farms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bonny Lad Farms Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2016 at 9:28am
To the best of my knowledge that situation always indicates a worn out gear.
There is no physical adjustment on the selector, internally or externally. Usually this indicates that there is just plain old wear on the gear to where there isn't a sufficient amount of surface to engage with and hold.
What should look like a relatively squared front on the gear will look like very rounded.
Hope that helps. Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richmar Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2016 at 9:30am
Steve:
Thank You!
Rich
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bonny Lad Farms Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2016 at 9:32am
No problem.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2016 at 6:56pm
You also may want to look at the gear shifter rails.  We found that there was very little problem with them when we sold them but after all this time the detent spring may be broken or the shifting rails worn.
Move the shift lever around and see if when you place it in gear that you have a solid feel.
If not drain the oil from the transmission and remove the shifter place located on the left hand side of the transmission.  Check the high shifter rail to see if has a solid move into place.  If not then remove it.  Be careful cause the detent balls can fly out.  May be a detent spring or a damaged rail.
We had to do this a lot with the WC shifter but not much the B-C shifter.
Let me know by private mail on this site and I may be able to give you more detailed information.
Good Luck!
Bill Long
Edited by Bill Long - 25 Jul 2016 at 6:58pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2016 at 6:56pm
